Code clearance between ABS and recessed lighting?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Buttonsrtoys, Jan 12, 2013.
  1. Buttonsrtoys
    Buttonsrtoys New Member
    Nov 1, 2012
    Nova Scotia, Canada
    I'm installing a new ABS drain and have a recessed can in the same joist bay. Is there a code requirement for how close I can be to the lighting fixture? There was some discussion in the archive to follow the lighting mfg recommendations, but its an existing light and I don't have anything on it. I could move the light to the next joist bay, or jog the drain into the bay, but am wondering if its worth the trouble.
  2. jadnashua
    Is the can an IC rated fixture? Would the things actually touch? WIll it run to the side or over the fixture? Sometimes, the fixtures have a label on them describing required clearances, or at least a manufacturer and model number which you could look up. It probably won't be an issue, but need more details. Jogging drainage pipes requires some considerations, such as cleanouts when the change in direction exceeds certain amounts. Best to be avoided.
  4. Buttonsrtoys
    Nov 1, 2012
    Nova Scotia, Canada
    Thanks for the thoughts. Below is a pic of the fixture. It's installed in a basement acoustic tile ceiling. The sticker reads, "Warning: Risk of fire. Do note install insulation within 3" of fixture sides or wiring compartment, nor above fixture in such a manner as to entrap heat."
    I was planning to the ABS next to the fixture, maybe 2" away.
  5. big2bird
    big2bird IBEW Electrician
    Sep 29, 2012
    IBEW Electrician
    Anaheim, Ca.
    Not an electrical issue. I do not know if it is a plumbing issue.
Similar Threads: Code clearance
Plumbing Forum, Professional & DIY Advice Design for rebuilt stack - does it meet code? Feb 21, 2017
Plumbing Forum, Professional & DIY Advice Code for wall hung boiler in bedroom Feb 17, 2017
Plumbing Forum, Professional & DIY Advice Is my drain/vent plan code compliant? Dec 5, 2016
Plumbing Forum, Professional & DIY Advice 30" code for toilet....15" from center to? Nov 30, 2016
Plumbing Forum, Professional & DIY Advice Foundation Drain to Sump - Code Rqmts? Sep 20, 2016
