Code and cutting studs
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Billy_Bob, Apr 13, 2008.
  1. Billy_Bob
    Billy_Bob In the Trades
    Apr 2, 2008
    I see in my handy plumbing code book that is some situations, you can cut away up to 40% of a wood stud for a pipe...
    But can I cut away more than that and then reinforce the stud in some way?
    Like maybe install a metal bracket over the end which is cut to give the stud back its structural strength?
    Or sister a length of stud next to the cut out stud?
  2. hj
    holes
    They make stud shoes to reinforce the cut area. A sistered stud would have to be cut away just like the subject stud.
  4. srdenny
    srdenny Plumbing Contractor
    Sep 11, 2004
    Plumbing Contractor
    SF Peninsula
    Billy Bob
    I don't know where you are, but if your jurisdiction is governed by the UBC, you can't notch or drill more than it says you can, even if you use stud shoes. See chapter 23 UBC. It does allow you to drill up to 60% of non bearing walls, "or in any wall where each stud is doubled, provided not more than two such successive doubled studs are so bored."
  5. hj
    shoes
    In a bearing wall, I can drill a 2" pipe through a 2x4 as long as I use the stud shoes. In a non-bearing wall, I don't need the shoes.
Similar Threads: Code cutting
Plumbing Forum, Professional & DIY Advice Design for rebuilt stack - does it meet code? Yesterday at 5:18 PM
Plumbing Forum, Professional & DIY Advice Code for wall hung boiler in bedroom Friday at 9:56 AM
Plumbing Forum, Professional & DIY Advice Is my drain/vent plan code compliant? Dec 5, 2016
Plumbing Forum, Professional & DIY Advice 30" code for toilet....15" from center to? Nov 30, 2016
Plumbing Forum, Professional & DIY Advice Foundation Drain to Sump - Code Rqmts? Sep 20, 2016
