clunking noise
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by lupemark, Jun 27, 2011.
  1. lupemark
    lupemark New Member
    Jun 27, 2011
    Frankfort IL
    Help me someone please?
    Not sure what my problem is but whenever I shut off my kitchen water faucet it makes this clunking noise in the pipes.
    The noise sounds if the copper lines are shaking or something.
    Has anyone come across this before and may be of help with what I need to do?
    Thank you.
  2. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    Sounds like water hammer. Install hammer stops.
  4. jimbo
    jimbo Plumber
    If the problem was not always there...then we ask what has changed? First thing would be to take pressure readings on your water supply, with the water off, and with water running. If it is too high, that can cause hammer where it didn't exist before
  5. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    Also what type,brand of faucet,could be the divirter if it has a sprayer.
  6. lupemark
    lupemark New Member
    Jun 27, 2011
    Frankfort IL
    It's a Moen faucet that's been on the sink now for maybe three years.
    This faucet is the kind with the sprayer built into the faucet (1 pieces assembly) so this could have a problem there?
    As for hammers...I need to investagate on what/how to install this. I'm what you wold call an extreme novice plumber. I'll tackle jobs that I feel I can handle and seek help for the others.
    Thank you for your response!
  7. hj
    If it is NOT water hammer, then arrestors will be completely useless, and a waste of time and money. And if it is a "pull out spout sprayer" it does not have a diverter, and even if it did it would usually cause the noise when the faucet was turned on, not off. You may need to have a plumber check the system to see where the noise is occurring, and why, so he can decide how to fix it.
  8. jimbo
    jimbo Plumber
    For $10, you can buy a simple pressure gauge at the hardware store. Connect it to a hose faucet in the back of the house, or perhaps where the cold water hose for the washing machine connects. Check the pressure when everything is off, and when a faucet is running wide open. Also observe the gauge as someone turns off that faucet.
    This will give you some insight as to where the problem may or may not be
Similar Threads: clunking noise
Plumbing Forum, Professional & DIY Advice "Clunking" noise when water first turned on Jul 9, 2007
Plumbing Forum, Professional & DIY Advice Clunking noise in bathtub after toilet flush Nov 2, 2005
Plumbing Forum, Professional & DIY Advice Clunking from Kitchen Faucet When Turning ON (AmStand 4174.501) Feb 7, 2012
Plumbing Forum, Professional & DIY Advice Loud clunking when pump turns on Jul 16, 2008
Plumbing Forum, Professional & DIY Advice Clunking pipes May 5, 2006
