clue less
Discussion in 'Electrical Forum discussion & Blog' started by Ford2001, Sep 14, 2009.
  1. Ford2001
    Ford2001 New Member
    Sep 11, 2009
    property care taker
    Manchester, Vermont
    Would someone out there please explain to me what a, 'Ring Main is?
  2. jbfan74
    jbfan74 Electrical Contractor
    Jun 14, 2007
    Newnan, GA
    It is a term used in th UK for a main electrical circuit(I think)
  4. hj
    loop main
    In plumbing it is the equivalent of installing a gang shower with the pipe going from the valve to both ends of the manifold to minimize flow losses. In electric it is a wire that starts at the circuit breaker and circles the circuit and comes back and connects back to the circuit breaker. It has no value unless the wire size is too small, or too long, for the load, which would usually mean the circuit breaker was too large for the wire.
  5. Ian Gills
    Jul 24, 2007
    USA
    In electricity supply, a ring final circuit or ring circuit (informally also ring main or just ring) is an electrical wiring technique developed and primarily used in the United Kingdom that provides two independent conductors for live, neutral and protective earth within a building for each connected load or socket.
    This design enables the use of smaller-diameter wire than would be used in a radial circuit of equivalent total current, which considering we are on 240 volts is very small indeed. Ideally, the ring acts like two radial circuits proceeding in opposite directions around the ring, the dividing point between them dependent on the distribution of load in the ring. If the load is evenly split across the two directions, the current in each direction is half of the total, allowing the use of wire with half the current-carrying capacity. In practice, the load does not always split evenly, so thicker wire is used.
    So, we use fewer breakers with less and thinner wire. Before you get all high and mighty, remember that all devices that we plug in are individually fused. The plug on the kettle, for intance, will have a 13 amp fuse in it. The plug on a radio might have a 1 amp fuse in it. Unlike the US where plugs are not fused and everything relies on the breaker, which means our poor little radio in the US gets the full 15 amps plus if it develops a fault.
    If you hadn't thrown our tea in the water, you'd know this.
    I actually prefer your system though because you need to be less clever to use it.
  6. nickdel
    nickdel New Member
    May 8, 2009
    Wow, you guys certainly can hold a grudge :D If we hadn't thrown your tea in the water we'd be saying ridiculous things like bugger off and cheerio and bullox.
  7. Ian Gills
    Jul 24, 2007
    USA
    And seeing you guys flying the flag and getting the fireworks out every fourth of July isn't?
    Tea parties in Washington DC and I am supposed to find that funny?
    Being booed and hissed every time I go on a guided historical tour?
    The real problem I have is that the water you threw the tea into wasn't even hot!
  8. nickdel
    nickdel New Member
    May 8, 2009
    Well, it might just be an overwhelming sense of pride at having beaten back the bullies. I don't think it's a grudge, mainly because I've never heard anyone wave the flag and scream anything about the British. These days it's usually, "Down with Al Quaeda," or, "Say no to the public option!"
    Yes, when those people are calling themselves teabaggers.
    Who is booing and hissing you while you're on a guided historical tour? And why? Are you making comments like, "British electricians are more clever than you yanks!" BOO! HISSSSS!
    ...and the world cheered as iced tea was invented
  9. hj
    tea
    And maybe if we had not thown the tea in the water, it would be like someone told a Frenchman when he complained about conferences using English. " If it were not for the English speaking countries, these conferences would be held in German".
  10. Norcal01
    Norcal01 New Member
    Aug 16, 2008
    I think it had something to do w/ who won the war.....:D Be glad otherwise there would have been pictures of the Fuhrer in homes & classrooms & we would be writing this in German.:(
  11. frenchie
    frenchie Jack of all trades
    Dec 30, 2006
    Caretaker
    Took a few more years to realize it shouldn't be salty, though.
Similar Threads: clue less
Electrical Forum discussion & Blog Tankless water heater ... dedicated to washing machine Jul 11, 2015
Electrical Forum discussion & Blog Question regarding wireless light switch Oct 15, 2014
Electrical Forum discussion & Blog Tankless Electric Oct 5, 2014
Electrical Forum discussion & Blog Wiring in a 220 circuit for Tankless water heater - Cunduit from behind the wall? Nov 21, 2013
Electrical Forum discussion & Blog Question? Will a Energy efficient dryer cost more or less then a Gas dryer Sep 14, 2011
