JosephK
I need to remove the current closet flange in order to tile the floor and install a new closet flange on top of the flooring. I'm assuming I need to cut the pipe? I was able to unscrew the flange from the floor, but I can't unscrew it from the plastic pipe. I guess it's glued and the only way to remove it is to cut it.
I have two questions. First, where should I cut the pipe? just under the flange?
Second, if I cut the pipe, will I need to get a drain pipe extension and coupler for the new flange (which will be higher due to the backer board and the tile)?
Thanks for any advice or redirection.
