Closet Flange arrangement....
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by hhcibtpaun, Mar 31, 2009.
  1. hhcibtpaun
    hhcibtpaun New Member
    Feb 17, 2009
    Pennsylvania
    I am rounding the corner on my basement plumbing and had a final question on plumbing the toilet.
    For the toilet I have a 4x3 hub/hub closet connector. I will need to put a 4" pipe into it to bring it to the floor level. Since I am not 100% sure what I will be doing with the floor I am not sure how high to bring the pipe. Is it better to just bring it up high, then cut after the fact? My fear is that I will not be able to cut the pipe flush with the floor, without damaging the floor. I was originally going to bring it about 3/8" - 1/2" above the concrete, then even if it was a little lower than then the floor, when I put the flange in, I would still get about an inch of engagement. What is the best way? Do you glue the flange in (I assume you do).
    Basically, I guess the question is, should I bring the pipe about 3/8" above the concrete. I figure if I do Tile, I will have 1/2" of floor, but to be safe I would be a little short. The closet flange has about 1.5" of engagement, so even if I was off by 1/4" or so I assume I would still be good????
    TIA...Mike
  2. jadnashua
    If you use an internal mount flange on the 4" pipe, you can leave it high then cut it flush with the floor when done. Just make sure it is plumb, or the flange won't sit flat. If you notch the tile first, you won't have to drill holes in the tile to mount the flange to the subflooring.
    I'm not sure you're using that fitting properly, though. See what the pros have to say. You may have it in backwards, and for what you want, need a 4x4. You normally don't want to go from a bigger to smaller pipe, but I think there are some exceptions right at the flange...check to be sure.
  4. iminaquagmire
    iminaquagmire DIY Senior Member
    Dec 16, 2007
    FF/EMT
    Leave the riser high. I put down blue painter's tape, and then duct tape before cutting with either a sawzall or a Japanese pull saw. The painter's tape is just extra insurance so the duct tape would come off easier and not leave a residue that would inhibit the sealer for the tile from penetrating.
    [​IMG]
    [​IMG]
  5. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    One of these will also work...
    [​IMG]
  6. hhcibtpaun
    Feb 17, 2009
    Pennsylvania
    I think I need one of them. Thanks for all the comments everyone.
    Mike
Similar Threads: Closet Flange
Plumbing Forum, Professional & DIY Advice Closet flange problem! Feb 27, 2017
Plumbing Forum, Professional & DIY Advice Closet flange questions Jan 10, 2017
Plumbing Forum, Professional & DIY Advice Cracked elbow below closet flange Dec 24, 2016
Plumbing Forum, Professional & DIY Advice Closet Flange on Slab - ack! Nov 23, 2016
Plumbing Forum, Professional & DIY Advice Cast iron closet flange questions Oct 23, 2016
