clogged vent stack
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Adam Myers, Jan 3, 2012.
  1. Adam Myers
    Adam Myers New Member
    Jan 3, 2012
    Roofer
    Annandal, MN
    okay so I have that smells coming out of the toilet in the stack and I figured the vent pipe was clogged and it is. So I took the advice of some and tried the auger and that didn't work, I then use the garden hose with a high-pressure nozzle and turned the water on, the stack filled with water and has not gave yet, it's winter here so now I have two problems I still have a clogged event and it may be possibly frozen in the morning, what do I do?
  2. hj
    If the auger did not work, assuming you used the correct one, then it might have been ice clogging it in the first place.
  4. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    You can use a shop vac to suck the water out of the top of the stack. Tape the hoses together good so you don't lose them in the stack.
    Don't fall off the roof. Don't let the vacuum fall either.
  5. hj
    A short hose filled with water should siphon the water out.
  6. schustermarie54
    schustermarie54 New Member
    Jan 7, 2012
    Denmark
    Maybe someone dropped a huge bomb with a bird sitting on the edge of the pipe and passed out from the fumes. All joking aside though i would imagine one sniff of the top of the vent gives a pretty good idea if its working or not. I always try to find something else to do when it comes time to work around a vent.
Similar Threads: clogged vent
Plumbing Forum, Professional & DIY Advice Drain Clogged Or Vent Issue? Friday at 1:00 PM
Plumbing Forum, Professional & DIY Advice Reasonable to assume I've got a clogged vent? (Video) Jul 31, 2014
Plumbing Forum, Professional & DIY Advice Slow drain actually might be clogged air vent Mar 14, 2014
Plumbing Forum, Professional & DIY Advice Old house, severly clogged vent stack, tools dropped in Oct 6, 2012
Plumbing Forum, Professional & DIY Advice Main Vent Clogged Oct 14, 2009
