Clogged vent stack or drain?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by rawktron, Aug 26, 2005.
  1. rawktron
    rawktron New Member
    Aug 26, 2005
    So we have a plumbing issue that we just can't figure out.
    When flushing our toilet, the toilet sucks the water out of the trap in the wash basin, but it does consistently flush ok and has not backed up. The other symptom however is that our bathtub drains very slowly - but doesn't appear to be clogged up with anything as it also drains.
    Septic system was just recently pumped, it was getting full, but everything looked to be in order.
    The only thing I can think of is that maybe the vent stack is clogged (haven't checked yet), but is that consistent with what we're seeing? Could something else be clogged?
  2. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Fill up the lav and then pull the stopper . Does the water drain out with a suction? Or does it bounce the water in the toilet some?
    Might pe a partially plugged section of the sewer, or something in the vent pipe.
    You say the toilet flushes, but I eonder if it flushes like it should.
    Run water with a garden hose down the stack on the roof . You should be able to hear the water draining all the way down the line.
    If your on the roof have someone flush the toilet. If you hear a glub-glub, then the sewer is slow and needs to be cleaned to the septic tank.
  4. rawktron
    rawktron New Member
    Aug 26, 2005
    Tried the filling up the sink, seems to drain fine... the mystery continues...
  5. alhurley
    alhurley Guest
    how old is the house? are the stacks open at the top (not capped or screened)? do you have a lot of tall trees?
    if it's an older (20+) house in a forest it wouldn't hurt to get the stacks flushed. you can often do it yourself if you have a long hose and adequate pressure - and you're not averse to walkin' around on your roof. otherwise get a plumber. and then put a cap or screen on dem stack openings. ;)
Similar Threads: Clogged vent
Plumbing Forum, Professional & DIY Advice Drain Clogged Or Vent Issue? Apr 29, 2016
Plumbing Forum, Professional & DIY Advice Reasonable to assume I've got a clogged vent? (Video) Jul 31, 2014
Plumbing Forum, Professional & DIY Advice Slow drain actually might be clogged air vent Mar 14, 2014
Plumbing Forum, Professional & DIY Advice Old house, severly clogged vent stack, tools dropped in Oct 6, 2012
Plumbing Forum, Professional & DIY Advice clogged vent stack Jan 3, 2012
