Clogged toilet help
Discussion in 'Toilet Forum discussions' started by juajuslee, Jan 23, 2011.
  1. juajuslee
    juajuslee New Member
    Jan 23, 2011
    Burnaby, BC
    Hi
    i need help with my clogged toilet but there is a big problem.
    someone put plastic wrappers in it and now it only slowly sucks water in.i tried the toilet toilet plunger but it doesn't work.
    Any help please?
  2. jadnashua
    You may need a toilet auger, or pull the toilet and fish them out if that doesn't work.
  4. juajuslee
    Jan 23, 2011
    Burnaby, BC
    can it work in a apartment?
  5. Terry
    Aug 17, 2004
    Plumbing is a home is the same as in an apartment.
    If you have plastic stuck in the trapway, you will need to pull it out.
    It would make sense to pull the bowl, and use the closet auger from the bottom to push it back into the bowl.
    Pushing it down into the drain may not be a good idea. Right now you only have a plugged toilet.
  6. jadnashua
    A toilet auger is a hand tool. Some work better than others.
Similar Threads: Clogged toilet
Toilet Forum discussions When toilet's clogged, flapper won't close Aug 9, 2016
Toilet Forum discussions Toilet clogged? Please help Jan 26, 2016
Toilet Forum discussions Toilet won't stay unclogged Sep 7, 2015
Toilet Forum discussions Clogged toilet, shower, sink combo May 6, 2015
Toilet Forum discussions New Drake Toilet Clogged Apr 15, 2014
