clogged sewer or bad sump pump?
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by rob6ert, Aug 29, 2005.
  1. rob6ert
    rob6ert New Member
    Aug 29, 2005
    I live in a 7 year old house with a sump pump. For the first 6 years, we never had a drop of water. About one year ago, we had a very heavy rain and we had water in the basement. It came in all around the perimeter of the room. We figured it was just because the rain was very heavy. About three months ago, we had water again during a hard rain. I called a handyman who replaced the sump pump telling me the old one was full of silt. We relaced it with a RIGID 1/2 horse pump. Since then, when it rains, I notice that the pump works fine for the first 15-20 minutes, then the crock begins to fill rapidly. After the rain stops, it sometaimes takes four to five hours of continuous operation to empty. If I unplug the pump the water level does not change, so I know the drain tile is empty. Also, we have four drains outside in window wells that look like they are not taking water also. Does this sound like a blocked sewer line?
  2. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    The four window well drains sound localized with the drainage problems. The situation with your pump would be likely the location of where the new pump was set or different float config that is allowing the pump to pump out the water table differently. It's always better to have a pump run continously for long stretches removing water than constant start and stop, start and stop. Not only hard on the float switch but it costs more electricity with that setup. I couldn't tell you how many sump pumps I have replaced where people think that you can set the discharge line 4 feet outside the foundation wall. They think water stays on top and never goes back to the lowest point, the sump pit.
Similar Threads: clogged sewer
Pumps and Tanks Well Forum & Blog. Water is life. Clogged washer inlet Oct 12, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Clogged well point Aug 17, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Deep water well completely clogged May 10, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Cyscle Stop Valve Clogged? Aug 9, 2009
Pumps and Tanks Well Forum & Blog. Water is life. Clogged french drain Jan 29, 2009
