Clogged drain valve in water heater
Discussion in 'Water Heater Forum, Tanks' started by sassyav8r, Feb 10, 2009.
  1. sassyav8r
    sassyav8r New Member
    Dec 16, 2007
    airline dispatcher
    grapevine, tx
    Hi guys-
    First of all, thanks for all of the past advice and tips. You all are the best.
    Secondly, I have a 6 gal. under sink point of use water heater that is
    needing replacement. I can't seem to get it drained. I've opened the faucet, hooked up a hose, opened the t&p valve, banged on the side of the drain valve, turned the cold water back on to try and flush the clog, all done in various combinations.
    I am at a loss. It is leaking now and I'd like to get it out before it
    ruins my hardwood floors. Any suggestions? I'll attempt to load a
    photo later.
    Thanks in advance for your help.
    Sas
  2. SewerRatz
    SewerRatz Illinois Licensed Plumber
    Nov 20, 2008
    Chicago Illinois Licensed Plumber
    Chicago, IL
    I have ran into this problem with the 6 gallon units, along with some of them where not even piped with a drain valve. Way I handled it was I opened the union and had my wet vac running the whole time till the tank was empty.
  4. sassyav8r
    Dec 16, 2007
    airline dispatcher
    grapevine, tx
    Thanks for your reply. I've gotten some of the water out via the t & p valve but am wondering how much it would weigh if I tried to pull it out now. I figured there's probably 5 gal. left weighing approx 9 lbs each and the tank itself full of sediments likely weighing 15, so is 60 lbs. about right?
  5. SewerRatz
    Nov 20, 2008
    Chicago, IL
    There abouts, I have tanken out full water heaters before. Not the easy way. One thing you could do is try to remove the drain valve. If it snaps off its no biggie, but again have a wet vac handy.
  6. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Cut it out and carry it out full.
    Be glad it's not an 80 gal. water heater.
  7. sassyav8r
    Dec 16, 2007
    airline dispatcher
    grapevine, tx
    That's what I've decided to do if I can't drain it. I'm tired of messing
    with the drain valve. I'm very glad it's not an 80 pounder. I'm just a
    little 5'4" chick. :)
  8. Redwood
    Dec 15, 2007
    Service Plumber
    Ummm Sassy,
    I was talking about being glad it wasn't an 80 gallon water heater.
    It would weigh about 850 Lbs. full!:eek:
    Yours will weigh about 85 Lbs.
  9. sassyav8r
    Dec 16, 2007
    airline dispatcher
    grapevine, tx
    LOL, yea, that's what I meant. That's what I get for typing and carrying on a conversation with someone else.
    Thanks
  10. hj
    heater
    I have NEVER drained a 6 gallon heater before removing it. Just cut or unfasten the pipes depending on whether it is a top or front connected model, the lift it out and let it drain outdoors.
  11. sassyav8r
    Dec 16, 2007
    airline dispatcher
    grapevine, tx
    That's exactly what I ended up doing. It wasn't too heavy. Thanks for all the replies. Now I have to figure out what the plumber was thinking when he hooked it up.
  12. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    If you can be more specific about your comment about what the plumber was thinking when he hooked up the old heater, we might be able to offer some help.
  13. hj
    heater
    He was probably thinking, "Now all I have to do is get water into the heater and then out to the sinks and I am done." How he did would be unique to EVERY plumber and situation. Why are you asking.
Similar Threads: Clogged drain
Water Heater Forum, Tanks Water tank drain clogged Nov 29, 2009
Water Heater Forum, Tanks Undersink hot water heater is semi-clogged Jul 8, 2015
Water Heater Forum, Tanks Question concerning water heater drain valve. Dec 21, 2016
Water Heater Forum, Tanks Need help draining a State water heater Oct 26, 2016
Water Heater Forum, Tanks Water heater (and A/C drain line) installation review Aug 17, 2016
