Clogged AC Evaporator line
Discussion in 'HVAC Heating & Cooling' started by vaman, Sep 26, 2009.
  1. vaman
    vaman New Member
    Jul 15, 2009
    NJ
    I have a 16 year old high efficiency central air where the evaporator condensate feeds into a pump to be removed. This week for the second time in abput 4 months the pvc line coming out of the evaporator clogged. There is a cleanout where I ran a brush through to clean it and it fixed the problem. But I have to think there is junk somewhere in the unit that is being dislodged
    I'm assuming probably somewhere "downstream" in the vertical pvc line feeding into the pump there is some junk. Is there something I can pore in the cleanout to flush any possible goo out?:)
  2. jadnashua
    Not sure, but I will tell you that one time on mine, I ended up with a woody fungus growth that essentially blocked the outlet...needed to be reamed out before I could pull the rest out.
  4. gator37
    gator37 Retired prof. engr.
    Nov 10, 2009
    Retired prof. engr.
    Alabama
    possible evaporator coil cleaning
    A cheap fix would be clorox solution if you can put up with the smell and don't drop it on the rug. Sounds like the coil may need cleaning along with the drain pan. (you been running the unit without a return air filter?)We use to use a chemical call Calgon to clean the evaporator coil with a soft brush but I don't know if they still make the chemical or not I am sure there is a replacement by now.
  5. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    Use a shop vac to suck it out.
    John
Similar Threads: Clogged Evaporator
HVAC Heating & Cooling Clogged Drain Line Caused Drip outside drip pan Sep 16, 2008
HVAC Heating & Cooling Goodman cased evaporator installation Oct 21, 2016
HVAC Heating & Cooling Evaporator Replacement Dec 14, 2015
HVAC Heating & Cooling LOW CFM effect and limits on evaporator/AC system ?? Aug 1, 2012
HVAC Heating & Cooling Residential Evaporator Coils Placement Jul 11, 2012
