cloged drain
Discussion in 'Drain Cleaning' started by texasitty, Aug 18, 2008.
  1. texasitty
    texasitty New Member
    Aug 13, 2008
    OK thanks to all the help i got .i REPLACED ALL MY PIPES ,BUT MY MAIN
    IS PLUGED I HAVE THE TOILET OFF. SHOULD I LEAVE IT OFF SO A PLUMBER CAN RUN THE SNAKE DOWN THERE. SINCE IT IS RIGHT THERE LAST TIME THEY WENT FROM THE ROOF VENT AND THAT DID NOT LAST VERY LONG.THE CLOG IS BETWEEN THERE AND THE TEE ABOUT 15 FEET AWAY .BECAUSE THE OTHER HALF OF THE HOUSE IS FINE.AGAIN THANK YOU FOR YOUR TIME....
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Leave it off and let him decide where to snake from.
  4. hj
    toilet
    I usually hate it when the customer removes the toilet because then I just have to spend additional time replacing it. Whether the plumber can use that opening or not depends on how you did the piping when you replaced it. Usually the answer is that it is not the best place and requires much more time to do it from there. The only difference between using the roof, or the toilet is how much extra cable it requires, so if the last time did not last long, it would not have been any different if he had used the toilet. The cause of the clog, and how long it takes to regenerate itself, determines how effective the snaking will be and how long it lasts.
  5. patrick88
    patrick88 Plumber
    Sep 3, 2007
    plumber
    Webster Ma.
    The drain machines work best the closer you are to the clog.
    It can be hard to run a snake through a closet bend, but it is sometimes the best place.
Similar Threads: cloged drain
Drain Cleaning How to use a sewer camera on a cloged drain? Dec 23, 2015
Drain Cleaning drain cleaner Yesterday at 8:25 PM
Drain Cleaning Two Droplets of drain cleaner Feb 18, 2017
Drain Cleaning Plugged 2" copper drain Jan 11, 2017
Drain Cleaning Hose to flush out p-trap/drain Dec 5, 2016
