Clearing line when pulling old toilet
Discussion in 'Toilet Forum discussions' started by magnumip, Nov 4, 2011.
  1. magnumip
    magnumip New Member
    Nov 3, 2011
    los angeles
    I figured maybe it might be a good idea to insure the line is nicely cleared while I have the old toilet pulled.
    I have a snake and could make good use of it while the wc is pulled. :cool:
    My question is this. Lately I have been using a cobra expanding water blatter attached to a hose at the clean out in the kitchen. If worked better than the snake does most of the time.
    How about using this set up at just inside the closet flange while I have the toilet pulled to install a new one?
  2. jimbo
    jimbo Plumber
    That bladder pump would help if you had a wad of tp stuck in there. It will do nothing for crud buildups.
  4. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    Running a stream from a garden hose into a 3" or 4" line for a water closet would likely do nothing to clear the line, there is simply not enough volume or pressure coming from the hose.
    A 3 or 4" cutter head on a rodding machine might make your efforts more worthwhile.
  5. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    What catcher_chick said plus forget about you hand powered snake. These are too puny and too short to clean a drain. It needs to be cleaned clear out to the street.
  6. magnumip
    magnumip New Member
    Nov 3, 2011
    los angeles
    I agree with the rodding machine. The only reason I asked this is in the past it has cleared well from a 3" kitchen clean-out where a 3/4" snake did not work.
  7. jadnashua
    The bladders release a quick surge of water which can poke a hole in a clog, but does not necessarily clear it. If you continually get clogs, there's likely something else going on - an improperly sloped drain, or a break, or a crushed line.
Similar Threads: Clearing line
Toilet Forum discussions Flushometer not clearing bowl Apr 24, 2014
Toilet Forum discussions Toto CST703 Toilet Not Clearing Jan 12, 2010
Toilet Forum discussions Kohler Highline Concealed Trapway Thoughts? Feb 16, 2017
Toilet Forum discussions New Home Sewer Line Clog Jan 8, 2017
Toilet Forum discussions Plumbing Supply Store vs. Home Centers vs. Online Jul 15, 2016
