Cleanout required?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Zenman, Dec 28, 2008.
  1. Zenman
    Zenman New Member
    Nov 26, 2004
    New Jersey
    I'm planning a 2nd floor bathroom remodel. The tub, sink and toilet drains all are tied together (3" PVC) and go down to the basement. Once in the basement the drain will go from vertical to horizontal at the basement ceiling to clear the HVAC ductwork. At this point do I need a cleanout? (wye on its back with the cleanout) Further down the line (past the HVAC ductwork) the 3" drain will go down again to meet the 4" drain which has a cleanout upstream of the 3" connection. This project is in New Jersey and we follow by UPC.
    To summize, do I need the 3" cleanout above the HVAC ductwork?
  2. jar546
    jar546 In the Trades
    Feb 20, 2008
    USA
    Yes, all horizontal drains require a cleanout. The toilet is considered a cleanout so that takes care of the horizontal drain for the new bathroom (the horizontal pipe for the tub/sink is considered waste pipe)
    There is more too it but the answer you are looking for is YES
  4. Zenman
    Zenman New Member
    Nov 26, 2004
    New Jersey
    Ok, thats what I thought - Thanks!
  5. hj
    cleanout
    I, and the inspectors around here, DO NOT consider the toilet an acceptable cleanout. And since the vertical drain should not, but apparently sometimes does, get obstructed, a cleanout in the wall above the toilet would be prudent.
  6. Zenman
    Zenman New Member
    Nov 26, 2004
    New Jersey
    HJ thanks for you input.
  7. hj
    cleanout
    IF could make the difference between a $150.00 snake job and a $500.00 one.
  8. jar546
    Feb 20, 2008
    USA
    HJ, I agree with you concerning placing a cleanout above the toilet.
    As an inspector, we are held to the codes and cannot ask any more. As you know there are many levels of plumbers out there who do minimum and never think about common sense or return service calls.
    Here is the definition of cleanout from the IPC to which I am held to. I cannot make up my own codes like other inspectors do, regardless of whether or not I agree with them.
Similar Threads: Cleanout required
Plumbing Forum, Professional & DIY Advice Cleanout Required in Vent Portion of DWV? Mar 17, 2014
Plumbing Forum, Professional & DIY Advice Would appreciate a review of my plumbing layout and esp. cleanout on horizontal runs Mar 8, 2016
Plumbing Forum, Professional & DIY Advice Cleanout question for 3" bathroom drain Feb 9, 2016
Plumbing Forum, Professional & DIY Advice Cleanout plug removal on cast iron help needed, 3.5" Oct 16, 2015
Plumbing Forum, Professional & DIY Advice Connecting new lav drain to existing branch, relocating cleanout Oct 12, 2015
