Cleanout plug leaking
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Mad Plumber, Nov 7, 2008.
  1. Mad Plumber
    Mad Plumber Mad Skills
    Aug 13, 2005
    Plumming
    I have cast iron sewer pipes. Several years ago, when the pipe was clogged, the plumber tried to remove the cleanout plug just inside the cellar wall. About a 3-inch piece of the threads that the plug screws into broke off at the bottom part of the opening. He replaced the cleanout plug with some kind of plug with a metal plate on the outside and a wing nut that expands the rubber (or whatever soft material seals leakage). Now, it's leaking and I fear that Im facing a huge repair bill, unless there is something I can do on my own. Please advise.
    Robert
  2. jadnashua
    Did you try tightening the wingnut?
  4. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    The line may be clogged with waste water holding in the line putting pressure on the plug. With a bucket under the plug you can carefully loosen the wing nut and see if the leaking increases. Be careful it may want to fly out. If the leaking increases I would call to have the drain cleaned.
    If the plug does not have water built up behind it but it is water leaking as it goes by down the waste line, tightening it may stop the leakage.
Similar Threads: Cleanout plug
Plumbing Forum, Professional & DIY Advice Brass cleanout plug in older home Jan 31, 2017
Plumbing Forum, Professional & DIY Advice 3" Cleanout Plug Won't Screw On Aug 11, 2016
Plumbing Forum, Professional & DIY Advice Cleanout plug removal on cast iron help needed, 3.5" Oct 16, 2015
Plumbing Forum, Professional & DIY Advice kitchen sink pluged/glued/broken cleanout Apr 20, 2015
Plumbing Forum, Professional & DIY Advice Opening up P-trap cleanout plug Jan 26, 2015
