Cleaning turbo torch tips?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by TMB9862, Feb 17, 2008.
  1. TMB9862
    TMB9862 New Member
    Nov 12, 2006
    How do you guys clean these out? I've got a bunch of them that either have a horrible flame or spew black gunk all over. I finally ran out of extra tips and it's now either clean em up or buy new ones. I know you can remove part of the bottom with an allen key but where do you go from there? Soak it in diesel, tiny wire brush, etc?
  2. krow
    krow Plumber
    Feb 11, 2008
    Ontario, Canada
    For my torch tips I usually replace the filter with a new one and the flame will be as good as gold
  4. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    Filters????
    I usually soak them in gasoline
    How do you change a filter on one of those ????
    Usually when all else fails I heat up the tip with another
    torch and that will clean out all the debris and solder balls that get
    inside one of them....
    I never knew that their was even a filter that could be changed
  5. srdenny
    srdenny Plumbing Contractor
    Sep 11, 2004
    Plumbing Contractor
    SF Peninsula
    Filters are on the bottom tof the tips. They come out with an allen wrench.
    A tip that has hardened solder in it might require heating up to make it flow out.
  6. Herk
    Herk Plumber
    Oct 28, 2007
    S.E. Idaho
    Tip #57: don't lose the orifice when you take it out to clean it. :eek:
Similar Threads: Cleaning turbo
Plumbing Forum, Professional & DIY Advice Cleaning the roots from the roof of a sewer pipe. Nov 18, 2016
Plumbing Forum, Professional & DIY Advice Gas Boiler Burner cleaning Sep 14, 2016
Plumbing Forum, Professional & DIY Advice Top 3 Tips for Drain Cleaning Aug 8, 2016
Plumbing Forum, Professional & DIY Advice Cleaning excessive purple primer on PVC pipes? Jul 30, 2016
Plumbing Forum, Professional & DIY Advice Cleaning foam and adhesive off abs before solvent cementing Jan 16, 2016
