cleaning toilet flange free of old wax
Discussion in 'Toilet Forum discussions' started by FJK, Jul 7, 2011.
  1. FJK
    FJK New Member
    Jun 15, 2005
    Illinois
    Due to a new floor, it looks like I am going to have to add a flange extender, using silicon to seal between the existing flange & the flange extension. I've done this before, but I don't remember and / or solicite a different opinion on how to get the existing flange totally free of wax. What is the best thing to cut through the residual wax particles.
    Also, do you just rely on the wood screws to clamp the flange extension, flange, & subfloor together, or do you somehow also incorporate the toilet mounting bolts into providing additional clamp load. I plan on using a Toto toilet that uses the plastic drain that bolts to the flange & also bolts to the finished floor. I forgot what this is called.
    Thanks, FJK
  2. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    I used acetone to clean the old flange. I used some long screws into the wood and I also drilled a few holes in the old flange and used Hardi-backer screws to fix the new to the old.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Whenever I use screws that may be exposed to moisture, I use stainless steel. They cost a bit more, but will not rust. Brass is too weak. For toilet flanges, I use #12 screws long enough to reach into or through the sub floor. I'm sure acetone will work fine, but you might also try mineral spirits-odorless preferred.
  5. hj
    Use long closet bolts which reach from the original flange, through the extenders, and up to the bowl, regardless of any other attachments you decide on to secure it.
Similar Threads: cleaning toilet
Toilet Forum discussions Self-cleaning toilet Oct 1, 2016
Toilet Forum discussions Cleaning Really Tough Toilet Stains Jun 3, 2016
Toilet Forum discussions Toilet cleaning Pucks Oct 25, 2015
Toilet Forum discussions Toto Neorest toilet seat cleaning Jun 19, 2015
Toilet Forum discussions Best performing bowl cleaning toilet May 7, 2014
