cleaning plumbers putty fingerprints of Stainless sink?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by bbillcee, Dec 10, 2008.
  1. bbillcee
    bbillcee Member
    Feb 25, 2007
    New York
    any suggestions?
  2. Cass
    Cass Plumber
    Nov 12, 2005
    WoW...try soap and water...
  4. bbillcee
    bbillcee Member
    Feb 25, 2007
    New York
    LOL i did they still show up ....i thought maybe there was a trick
  5. Sandpiper Plumbing
    Sandpiper Plumbing Plumber
    May 4, 2008
    Northern by birth, Southern by choice
    I use GlassPlus and a soft towel, let it soak for a few minutes and it usually wipes right out with a little elbow grease.
  6. bbillcee
    bbillcee Member
    Feb 25, 2007
    New York
    LOL sorry for the stupid question!:(
  7. Cass
    Cass Plumber
    Nov 12, 2005
    Try a damp rag with some dish soap placed directly on the rag and work it in...
  8. Cass
    Cass Plumber
    Nov 12, 2005
    Are you sure it is plumbers putty and not caulk...normaly plumbers putty comes right off...
  9. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    Stainless Steel Magic¿
  10. Mike Swearingen
    Mike Swearingen New Member
    Jan 12, 2005
    Independent Real Estate Broker
    On Albemarle Sound In Northeastern NC
    Oops! solvent and cleaner will dissolve most anything sticky, including chewing gun, adhesives, etc.
    Mike
  11. jadnashua
    SS can be somewhat porous, and most plumber's putty has some oil in it. Oil stains need a solvent to remove if embedded.
  12. hj
    fingerprints
    If his are on the sink then anyone else who touches it will also leave marks. Bartender's Friend cleaner is usually what is used.
Similar Threads: cleaning plumbers
Plumbing Forum, Professional & DIY Advice Cleaning the roots from the roof of a sewer pipe. Nov 18, 2016
Plumbing Forum, Professional & DIY Advice Gas Boiler Burner cleaning Sep 14, 2016
Plumbing Forum, Professional & DIY Advice Top 3 Tips for Drain Cleaning Aug 8, 2016
Plumbing Forum, Professional & DIY Advice Cleaning excessive purple primer on PVC pipes? Jul 30, 2016
Plumbing Forum, Professional & DIY Advice Cleaning foam and adhesive off abs before solvent cementing Jan 16, 2016
