Clay Pipe tie in
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by burked1234, Apr 7, 2011.
  1. burked1234
    burked1234 New Member
    Jan 21, 2011
    Pittsburgh, pa
    Hi-
    I have a 1916 house in Pittsburgh. When it was built, the gutters drained into the house and under the basement floor through the clay pipe that runs to the sewer. We changed this when we moved in as it was a code violation, and capped the pipes. I am thinking of adding a second bathroom in the front of the house, which is on the opposite end from the stack. There is a capped clay pipe in the basement directly under where i would put the bathroom. Any issues with tying into that for waste? I have a straight shot down to it, and can vent out above the roof on the side of the house.
  2. Basement_Lurker
    Basement_Lurker One who lurks
    Jun 21, 2007
    I smash things and demand money.
    Victoria, BC
    100 year old clay pipe? If you are going to the trouble and expense to put an addition on, you should think about replacing that deteriorating dwv system and bring it up to code. No doubt the lines have settled over the years and sections are not sloped properly.
  4. shacko
    shacko Master Plumber-Gas Fitter
    Jan 22, 2006
    Rosedale, Md
    Have to agree with (Basement_Lurker ) there's no way I would tie into existing clay pipe unless I was forced to.
  5. burked1234
    Jan 21, 2011
    Pittsburgh, pa
    Define "forced to" ;)
    The pipe runs under the a finished floor of the basement, so i'm not inclined to bust that open unless i have to (and getting out through the back yard would require demolishing my porch, so, probably not going to do that.
    but, good points non the less
  6. burked1234
    Jan 21, 2011
    Pittsburgh, pa
    i should also note that, i'm not planning on doing this myself, but hiring a pro for this kind of thing
  7. shacko
    Jan 22, 2006
    Rosedale, Md
    You might be close to being forced to; I would get a video of the line to be sure there is nothing wrong with it that might bite you, luck.
Similar Threads: Clay Pipe
Plumbing Forum, Professional & DIY Advice How to connect PVC to 7.25 in OD clay pipe? Jun 22, 2014
Plumbing Forum, Professional & DIY Advice PVC stack into cast iron cleanout tee into clay pipe Apr 7, 2014
Plumbing Forum, Professional & DIY Advice Opinions/Help/BS Detector Needed - Clay Pipe Replacement vs. Maintenance Jul 12, 2013
Plumbing Forum, Professional & DIY Advice Adding a clean-out to old cast iron and/or clay pipe Dec 2, 2012
Plumbing Forum, Professional & DIY Advice Clay drain pipe Oct 1, 2012
