Clay drain pipe
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Geo422, Oct 1, 2012.
  1. Geo422
    Geo422 New Member
    Feb 12, 2012
    Cin oh
    Hi I have an four inch drain pipe which is broken. What do I use to connected an four inch PVC pipe to the clay pipe ? Thanks George
  2. jb 10
    jb 10 New Member
    Apr 13, 2014
    WI
    I'll reply with the same question.
    Here's one for underground, pvc to clay:
    Here's a shielded coupling for above ground, but I can't tell if it can also be used with clay:
    The P3000 series shielded coupling is EPDM for cast iron. Can it be used for clay?
  4. asktom
    asktom Member
    Nov 9, 2009
    Victor, MT
    A number of companies make the all rubber couplings for clay to plastic. Cut out the bad clay then whack off a chunk of plastic a hair less than the length of the gap. The couplings will slide over the plastic so you can set it in place and slide the couplings into position.
Similar Threads: Clay drain
Plumbing Forum, Professional & DIY Advice Clay Drain Tile Repair Sep 9, 2014
Plumbing Forum, Professional & DIY Advice Questions Replacing Clay Sump Basin and Drain Tile Mar 28, 2014
Plumbing Forum, Professional & DIY Advice 6" Clay Drain to PVC to 6" Clay Drain Jun 30, 2010
Plumbing Forum, Professional & DIY Advice Sewage line cleanout by street - clay?? Sep 16, 2014
Plumbing Forum, Professional & DIY Advice How to connect PVC to 7.25 in OD clay pipe? Jun 22, 2014
