clawfoot tub water supply - flex?
Discussion in 'Shower & Bathtub Forum & Blog' started by ChrisRice, Sep 25, 2010.
  1. ChrisRice
    ChrisRice New Member
    Sep 25, 2010
    Indiana
    I have a clawfoot tub in a basement. The old supply lines - well - let's just say the decided to not work anymore. Putting the compression rigid lines back in place seems like a bad idea as the tub is set up in a way where they're pretty easy to bump
    What I'd like to do is replace the rigid supply line with the braided flexible lines. I've searched everywhere for someone trying to do the same thing and haven't had any luck finding one (including here), so if there's a thread already similar to this, sorry...
    Here's my issue:
    a 1/2FIP to 3/4FIP flexible line only seems to exist and they're out of stock for the next 2 mos or so. (I don't want to wait, but my guess is I'm going to have to)
    I tried a 1/2 to 1/2 hose with a brass 3/4 to 1/2 reducer on the faucet connections and it leaks like a sieve. I've tried pipe dope, teflon tape, both, none, tight, tighter, stupid tight, and everywhere in between and the leak always happens between the brass adapter and the faucet (hose connections work just dandy).
    Any thoughts on why this might be? I'm bamboozled by the whole thing.
    Any help, thoughts, suggestions and/or alternative ideas is much appreciated.
  2. shacko
    shacko Master Plumber-Gas Fitter
    Jan 22, 2006
    Rosedale, Md
    If you have a real OLD claw foot tub and faucets the connection to the faucets may not be a standard fitting, you may need part of what you have taken out to get it to hook up, sorry
  4. ChrisRice
    Sep 25, 2010
    Indiana
    Nope it's a 3/4" MIP it had a compression fitting rigid supply line on both ends. I could go that route again (I assume) it's just there's a 99.9999999999999% chance those lines will get bumped pretty good which is what caused the last failure.
    Tub's old faucet looks relatively new.
  5. Jerome2877
    Jerome2877 In the Trades
    Aug 25, 2009
    Vancouver Island , BC
    Its compression not mip, theres a difference.
    [​IMG]
    Rubber cone washers with friction rings.
  6. thassler
    thassler Member
    Dec 5, 2006
    Systems Analyst
    Tennessee
    You can get special supply couplings that will take your 3/4 faucet ends down to a 1/2" IPS male connection so you can then use standard braided faucet supply lines. You can google "clawfoot tub supply couplings". (I'd post a link on where I purchased mine, but I don't think the forum allows?)
    Trey
  7. Basement_Lurker
    Basement_Lurker One who lurks
    Jun 21, 2007
    I smash things and demand money.
    Victoria, BC
    sounds like you need a couple clawfoot ells
  8. ChrisRice
    Sep 25, 2010
    Indiana
    Awesome, thanks Jerome. I had no idea there was a difference.
    I've found some of the couplings you mentioned Trey (don't want to post link for reasons you mentioned) do they make them not in an ell form? The only thing I've been able to find are ells. Not going to be picky about it just curious. You can e-mail or pm me where you got yours I'd appreciate it.
    Thanks a lot.
  9. asktom
    asktom Member
    Nov 9, 2009
    Victor, MT
    Those will work. The threads on the valve are straight, not tapered like a pipe fitting. The seal is made by compressing a washer, not with the threads.
  10. ChrisRice
    Sep 25, 2010
    Indiana
    I wouldn't have ruined the threads on the faucet threads by trying to put the wrong fitting on it would I?
  11. thassler
    thassler Member
    Dec 5, 2006
    Systems Analyst
    Tennessee
    Shouldn't have. You couldn't get a seal using a female threaded adapter due to the threads on the faucet being straight and not tapered as asktom mentioned. The supply couplings (ells) use a flat washer that seals against the tip of the faucet pipe.
  12. ChrisRice
    Sep 25, 2010
    Indiana
    Fantastic. Thanks for all the help! Anyone has a web design, home theater, or pc trouble shooting question I'm all yours!
  13. hj
    Actually, the inlets to a tub faucet have a taper machined into them. In the old days we used solid "tailpieces with a tapered nose" and a lock nut to connect to the faucet. A flexible hose supply with a gasket will seal to the faucet, although I question how "pretty" it will look.
  14. ChrisRice
    Sep 25, 2010
    Indiana
    That's what I wanted to do initially just use a hose, problem is I've only found one with 3/4 on one end and 1/2 on the other and when I tried to order it there was a 70 day wait (maybe more), that was a month ago, so it should be approximately 40 days now, I was just trying to find a different solution.
    The flexible lines on there now (where the 3/4 to 1/2 coupler leaks) actually look pretty good. Pretty enough for the wife, so I think we're good.
    Thanks for the input. I feel like a tool for not realizing the threads were different!
  15. Terry
    Aug 17, 2004
    [​IMG]
    You can pick up solid risers still for the old clawfoot tubs. These are brass plated stops with rigid supply lines.
    There were from, Sign of the Crab
Similar Threads: clawfoot water
Shower & Bathtub Forum & Blog standing water in clawfoot tub Aug 23, 2009
Shower & Bathtub Forum & Blog clawfoot tub - 2 knob system and water usage Jan 13, 2009
Shower & Bathtub Forum & Blog Clawfoot water inlet valves leak!! Jan 10, 2009
Shower & Bathtub Forum & Blog Clawfoot bathtub gurgles Feb 20, 2017
Shower & Bathtub Forum & Blog Very stubborn spud/shoe on old clawfoot Jul 20, 2016
