Clawfoot tub refinish
Discussion in 'Shower & Bathtub Forum & Blog' started by Master Brian, Nov 14, 2008.
  1. Master Brian
    Master Brian DIY Senior Member
    Nov 13, 2008
    Kansas
    I am installing an old cast iron clawfoot tub. I repainted the exterior with an enamle paint, so that is take care of. I am just curious about what everyone would recommend for the porcelain inside the tub. It has some chips, but I have some patch stuff that is supposed to fix those and they aren't really very major. The worst part is there are rust stains on the porcelain. Originally, I had thought I would wait to refinish the inside until my very young kids are a bit older, but I am now starting to wonder if I should go ahead and do it now before I install it.
    What would you recommend, do-it-yourself kits or hire a professional? If a professional, what is a reasonable charge? My sister paid $300-400 for a newer cast iron tub to be refinished, but my brother said he thought it could be done for $100-200.
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    I would go with thw professional job for best results.
    I would question installing a used tub in need of refinishing though.
  4. Master Brian
    Nov 13, 2008
    Kansas
    Thanks. I am starting to question that as well, especially when it turned out that a tab that holds one of the feet on was broken, but after spending $300 on a replacement foot cradle, I'm sticking with this tub. Even if I spend a few hundred on refinishing it, I'm still well over a grand less invested than I would have been buying a lower end new clawfoot. I also like the fact that it was built in 1911.
  5. Tub Refinisher
    Tub Refinisher Tub refinisher
    Jul 1, 2008
    Self Employed Franchise Owner
    Dallas, Tx
    You won't get a quality job for $100-$200. $300 to $400 is more like it for a good job. I know, I do this for a living.
  6. hj
    tub
    New tub or old tub, it should cost about the same. If you do not eliminate the rust before refinishing it, it will cause the new finish to come loose.
  7. Master Brian
    Nov 13, 2008
    Kansas
    That's kind of what I thought, but had to ask.
    My question to you is do you by chance no anyone that you can refer me to that does this type of work on the antique tubs in the Wichita, KS area? I see you are in Dallas, which is a decent drive away, but doesn't hurt to ask....
    Being as the finish is still relatively good, just stained in some areas and a few small nicks, around the fittings and edges, I have to decide if I can live with it or not. This is of course a 97y/o tub, and just like any antique the flaws are part of the character. The problem is I wonder if it will look out of place with the shiny new hardware.
  8. Tub Refinisher
    Jul 1, 2008
    Dallas, Tx
    Try this guy in Wamego. I don't know if he goes that far or not. Tell him Barry from Perma-Glaze in Dallas sent you.
    http://www.permaglaze-ks.com/
  9. Master Brian
    Nov 13, 2008
    Kansas
    Will do, thanks!!
  10. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    No matter what,
    Make sure that when you have that tub refinished, demand that they pull that chrome tub drainpiece out of the tub along with the overflow plate and finish to the factory edges.
    I don't care if you're trim is brand spanking new, have them take it out and do it right.
    I've found too many of these refinished where I'm the lucky guy who has to replace the trim on a tub and either a retrofit was installed over the old to cover it, and I have to get to that overflow assembly and do it right.
    Then there's an edge between new and old which allows that stuff to peel right back up, at no fault of mine.
    I like the tub refinishes that have a very minute texture to it that's almost impossible to see by eye, but you can feel it. Like a slight orange peel finish.
    The prep part of these refinishing jobs makes these a good or no good idea.
Similar Threads: Clawfoot refinish
Shower & Bathtub Forum & Blog Clawfoot bathtub gurgles Feb 20, 2017
Shower & Bathtub Forum & Blog Very stubborn spud/shoe on old clawfoot Jul 20, 2016
Shower & Bathtub Forum & Blog Clawfoot tub faucet knobs turn on their own May 12, 2015
Shower & Bathtub Forum & Blog How to replace a clawfoot tub faucet and waste and overflow Oct 18, 2013
Shower & Bathtub Forum & Blog Clawfoot tub installation with pex stub outs Aug 6, 2013
