OK, I see this is a classic problem, but not sure which solution is best here. I am tiling my bath and the closet flange is roughed in on top of the subfloor. So the top of flange will be about 3/8 below finished floor when I tile.
I unscrewed the flange, and have enough play in the pipe to raise the existing flange. My idea is to insert two C-shaped spacers under the flange (the thickness of the hardi + tile.) Would plywood be good, or plastic spacers from Set-rite or Oatey etc snapped in half ?
http://www.set-rite.com/about.htm
End result, flange would be flush with floor, and I would then tile around it. Will this be the best option?
Or do I really need to cut off the flange and put in a new one that sits on top of the tile. Sounds like this is the ideal way for stability, but means replacing flange and drilling through tile.
OR, take the easy way out, leave it all alone and use an extended wax ring and/or spacers on TOP of the flange?
