Clack WS-1 CS Pricing?
Discussion in 'Water Softener Forum, problems, installation and r' started by shanlar, May 22, 2011.
  1. shanlar
    shanlar New Member
    May 22, 2011
    Elk Grove, CA
    Can anyone fill me in on the cost of a Clack WS-1 CS? I have a local dealer quoting me $540 for the valve, bypass, and yoke. This seems overpriced to me as I have seen an entire water softener build by Gary for $622.
  2. Akpsdvan
    Akpsdvan In the Trades
    Dec 29, 2009
    Business owner/service and sales
    Alaska
    Is your local dealer going to be there for you when you have challenges with the unit?
    How old is the Gary price of 622.00?
  4. rjh2o
    rjh2o Member
    May 10, 2011
    Michigan
    Any time a system is broken down and sold by components it will be more expensive. I believe you will need to order a different outlet manifold with the Clack anyway. It usually is less expensive (per component) to order the whole system and you will have a complete warranty on system. That really is not a bad price for a Clack valve from a local dealer.
    RJ
  5. Gary Slusser
    Retired
    As per Clack's contract with all their distributors, they and their dealers are not supposed to sell just a valve; a 'complete system' only.
    There is no "yoke" needed or for a Clack valve. There are various sized NPT connectors required.
    You live in CA.... prices are higher there for everything.
    My price is probably low due to not being 'calculated' recently. That's due to me being out of business since last June when Clack shut off internet sales of their valves. The web site is still 'up' to piss Clack off, plus it is prepaid until next Sept. And 3000-4000 unique visitors a month use the information on the site and the forum and I don't like the idea of preventing that.
  6. Gary Slusser
    Retired
    The Clack valves are the easiest and quickest to repair on the market. It/they was/were designed to be that way. It is the best design for serviceability also, so it needs service much less often than other valves but when it does it is very easy for a DIYer to repair; and there are no special tools required.
  7. Gary Slusser
    Retired
    "manifold"? Do you mean distributor tube or as some call them a 'riser' tube? The Clack WS1 uses an industry standard 1.05" OD distributor tube.
    The warranty is the same no matter who or where you buy it from or if you buy just the valve or a whole softener.
    Having sold many valves as a local and internet dealer, for a total of 24 years, IMO the price is high by $100+. But then that is based on my year old wholesale cost.
  8. shanlar
    shanlar New Member
    May 22, 2011
    Elk Grove, CA
    This local dealer wants to sell me a 2.0 cuft setup with a brine tank for a 1.0 cuft all for $2k. I could buy all the parts online, except the control valve from him, and still be under that price.
    He didn't really sound like he knew much about the programming and uses a 3/4" distributor tube for his builds and recommends it over the 1.05" for some odd reason.
    The "yoke" was referenced by him when discussing what was included in that price. Another reason to add onto the list of only purchasing a valve from this dealer and nothing else.
    Ok so what I am getting is I should be sticking around $440 for this valve. Thanks for all the helpful replies!
    PS. Gary if you want to make some extra cash and sell me all of the gear except for the valve let me know!
  9. Gary Slusser
    Retired
    You can learn about sizing by clicking the link in my signature. You may need a 2.0 cuft.
    IIRC you said you had a space limitation, a small (say 11" x 11") salt tank is used in those cases but... the salt tank size isn't based on the size of the softener, it is based on the number of lbs. of salt used per regeneration (regardless the size of the softener).
    A 1.05" OD distributor tube is nominally 3/4" ID.
    Sorry, I am out of business.
Similar Threads: Clack WS-1
Water Softener Forum, problems, installation and r Clack WS-1 stuck on "regen today" Oct 2, 2012
Water Softener Forum, problems, installation and r ws-1 clack Jun 15, 2012
Water Softener Forum, problems, installation and r Programming my Clack ws-1 Feb 23, 2011
Water Softener Forum, problems, installation and r Clack WS-1 Leak during brine cycle? Aug 28, 2010
Water Softener Forum, problems, installation and r Clack WS-1 Parts Dec 9, 2009
