City of Palo Alto rejects any drywall in wet areas - suggestions for backing?
Discussion in 'Shower & Bathtub Forum & Blog' started by rap, Mar 21, 2012.
  1. rap
    rap New Member
    May 8, 2010
    california
    The Building Dept of Palo Alto rejects the use of green or any other drywall in wet areas. To achieve a S&C floated surface for tile, what other backing suggestions would you recommend? Perhaps a Two-Coat float over mesh and 15 lb felt?
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    Everyone in the country is using cement board, or some variation of it.
    It's been this way for a quite a few years now.
  4. jadnashua
    They seem to be oblivious that if a waterPROOF surface membrane is applied properly, the drywall is NOT in a wet area. But, trying to talk sense into some people is useless. The only thing I'd consider is to show them the TCNA method approval that allows it. But, as said, it's based on a proper install. You do what you have to, so cbu, while harder and more expensive, is usable underneath any of the surface membrane materials, either painted on or those in sheets. Note, not all sheet membranes support drywall - the TCNA procedure references the manufacturer's recommendations. Kerdi, for one, prefers this, but is equally viable over other backing materials to meet local ammendments to the TCNA procedure. I guess the thousands of installs that are in great shape has no credence...fighting city hall is possible, but sometimes not worth the effort when a viable alternative is available.
  5. dlarrivee
    dlarrivee New Member
    Jun 28, 2009
    Foam/Fireproofing/Acoustical
    Canada
    Jim we both know that people expect to hang board and tile right over it, I'm sure that is why the county is not allowing it.
    What about fibreglass faced gypsum board?
  6. jadnashua
    Seams where it's been cut are still problematic unless it's properly waterproofed. guess you just have to ask them what they'll allow.
  7. dlarrivee
    Jun 28, 2009
    Canada
    Problematic how?
    You could use fibreglass faced drywall everywhere in a bathroom, waterproof the wet areas, and skim coat the rest.
  8. jadnashua
    While fiberglass may not be mold food, if you get gypsum wet, it can turn to mush, so any seam has the potential of being a problem...depends on how well you put things together, but it's not cbu which doesn't really care if it gets wet.
  9. jimbo
    jimbo Plumber
    San Diego, CA
    If by wet area you mean the shower, it has not been approved for 20 years to use any kind of drywall under tile. It MOIST areas, like the walls and ceilings in a bathroom, they came out with the "greenboard" but it really was not the answer. They do now have blueboard, which does not support mold growth, but it is not water resistant. Use cement board, or actual lath and mortar, under tile in showers and on the floor.
  10. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
    Post(s) deleted by John Whipple
  11. dlarrivee
    Jun 28, 2009
    Canada
    Be careful, if I didn't know any better I would say that John makes more money promoting products on the internet than he does remodeling bathrooms.
  12. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
  13. dlarrivee
    Jun 28, 2009
    Canada
    Are you related to Billy Mays?
  14. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
  15. rap
    rap New Member
    May 8, 2010
    california
    Thanks for your replies, but i'm not much further ahead. I'm looking for a sound method of floating given the above conditions. Backer board is obviously not the answer.
    AAMOI, San Jose bldg dept were passing shower walls with drywall behind a floated coat up to 2001, as far as i recall.
  16. ballvalve
    Dec 28, 2009
    northfork, california
  17. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    Why would you NOT want to do a wet area with CBU, which IS the industry standard for tile installation, both wet and dry?
    I suspect that you should research what is common practice in tile today.
  18. rap
    rap New Member
    May 8, 2010
    california
    ballvalve, thank you for your post.
    cacher, the Gold Standard in tile backing was and is a floated coat. It's the quickest and easiest way to plumb and square out of line studwork - provided that
    one has the relatively simple plastering skill required. The method is commonly used in the West and the Southwest: see michael byrne and johnbridge.com
    I have demo'd floated shower walls from the 1920's where the tile ( read grout ) had failed long before, and yet no moisture had penetrated the backing to damage studs or structure, and this after 80 years of wear and Ca. earth tremors.
    Going a little further afield, one might view sound, tile installations over floated backings in Rome and Istanbul that were fixed over a 1000 years ago.
  19. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    I see a lot of lathe and horsehair plaster around here, which was the standard in it's day.
    Much like cast iron drains fitted with lead & oakum, galvanized supply pipe, drum traps, wiped lead joints, etc., etc., etc.
    I respect the old methods, but have moved on to to materials which are more user friendly.
    Going back to your original question- I don't understand why you would do a float coat over drywall, but cannot do the same thing over a CBU product?
  20. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    Squaring out-of-line studwork with CBU can be done before hanging the CBU by shimming/planing or after by skim coating. As for "the relatively simple plastering skill required" that must be a rare commodity given all the humps and built-up corners I've had to work around.
  21. Hackney plumbing
    Hackney plumbing Homeowner
    Jan 6, 2010
    Alabama
    Alot of people dont know this but cast iron is more forgiving that plastic at the fitting connections. You can deflect cast iron lead and oakum joints I believe up to 6 degrees. In other words you can make a 45 into a 51 degree or a 39 degree bend and still have a sound joint. You cant do that with PVC.
    Sorry I knwo thats kinda off subject. LOL
Similar Threads: City Palo
Shower & Bathtub Forum & Blog Riser load capacity calculation for a new shower Dec 15, 2015
Shower & Bathtub Forum & Blog GPM Capacity of 2" Shower Drain Aug 3, 2009
Shower & Bathtub Forum & Blog Calculating floor load capacity Nov 28, 2006
