City boy moves to the country.
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Rick29, Jun 9, 2010.
  1. Rick29
    Rick29 New Member
    Jun 9, 2010
    Paulding Ohio
    Sirs,
    I am buying an modular that sits in the country on 4 acres, and has a well and septic system. The modular has been empty for two years and was built in 1982. I was wondering what I need to do to restart the water system? It has been winterized. I have found two water lines unhooked. So other than hooking up those water lines, what should I do?
    Thanks
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    Jet pump, submersible pump? Where do the two lines come from?
  4. Rick29
    Rick29 New Member
    Jun 9, 2010
    Paulding Ohio
    Sir,
    Outside, there is a lined hole with wiring above the hole with a cover, I am thinking the pump is in the hole. Inside the house there is a tank, looks something like the one in the picture in your answer and it goes to a water softener. I noticed that under one of the sinks the water lines were unhooked. I know that I will have to hook them back up. Also there is a new water heater in the house and it fells empty.
    Thanks
  5. Gary Slusser
    Retired
    Uploading pictures of the area and the hole with the cover will help a lot. Or at least tell us some dimensions, is the hole 3" or 3'. How many wires or strands? Colors of the wires. Where do they come from and go to?
  6. hj
    28 years old and unoccupied for 2 years? There are many POSSIBLE problems, but maybe none that you have to worry about. All you can do it reconnect the piping, and then energize it to see what happens.
Similar Threads: City moves
Pumps and Tanks Well Forum & Blog. Water is life. Large capacity well (100gpm) and home use Sep 13, 2016
Pumps and Tanks Well Forum & Blog. Water is life. City Water Uphill Oct 14, 2015
Pumps and Tanks Well Forum & Blog. Water is life. frankin 1hp pump not starting up, but using electricity Jul 5, 2015
Pumps and Tanks Well Forum & Blog. Water is life. adding a pump to city water Jan 5, 2015
Pumps and Tanks Well Forum & Blog. Water is life. City water + cistern + booster + pressure tank thoughts Oct 17, 2014
