circulator pump question
Discussion in 'Boiler Forum' started by shendog, Jan 6, 2010.
  1. shendog
    shendog New Member
    Jan 6, 2010
    PA
    Hey Guys, I orginally posted this over on the HVAC forum, but thought I would try it here also. Not really sure witch section it belongs in.
    I have just recently purcahsed a home (my first home). The home has oil hot water and heat; and a wood/coal stove backup. The wood stove is already plumbed into the house hot water system, but has no circulator of it own. The wood stove does have a controller for a circulator, and a wire has been run over to the circulator on the oil furnace; but not connected. My question is this: Can the oil furnace controller, and wood stove controller both be connected to the circulator pump simultaneously? My understanding is that these controllers are esentially relay switches, and there is no danger of back feed. However I want to be sure, before I connect it up that way. Don't want to let the magic smoke out of anything expensive!
    As always, I would greatly appreciate any help you can offer!
    Shen
  2. wooson
    wooson New Member
    Feb 6, 2010
    08085
    I can't see any problem with it. I ran a similar set up many years ago but manually valved one out at a time as to not heat the cold boiler. Do you pump throught the cold boiler or bypass? My set up was pretty primative but I had a lot of good hardwood, was young and energetic.
  4. hj
    It depends on HOW power is supplied to those two devices. BUT, unless there is proper piping in place the second switch may either NOT do anything, or it could upset the stability of the current operation.
  5. Dana
    Dana In the trades
    Jan 14, 2009
    01609
    What safeties are designed into this system to preclude a steam explosion at high-fire on the wood stove when the circulation is zero, as would be the case during a power outage?
Similar Threads: circulator pump
Boiler Forum How to tell if circulator is pumping? Nov 14, 2016
Boiler Forum Circulator Pump Noise - See Video Feb 15, 2016
Boiler Forum No power to circulator pump Nov 4, 2015
Boiler Forum Circulator Pump is pushing water through neighbor zones Feb 14, 2015
Boiler Forum Want to add speed control to a single speed circulator pump Jan 12, 2015
