Circuit short help
Discussion in 'Electrical Forum discussion & Blog' started by rockycmt, Nov 9, 2009.
  1. rockycmt
    rockycmt Member
    Nov 13, 2007
    New York Metro Area
    See the wiring diagram below. It is a small circuit. Homerun to the first outlet. It shorts out at the breaker when the switch is thrown to on. There is no load on the circuit so it is not an amp issue. Where is the problem?
  2. Cass
    Cass Plumber
    Nov 12, 2005
    Somewhere in the circuit...a diagram does not show problems...
  4. Billy_Bob
    Billy_Bob In the Trades
    Apr 2, 2008
    *Very* rarely, an outlet may have a manufacturing defect where the hot and neutral is shorted. (As in I have only seen this happen once.)
    Then other than that, turn off the main breaker, disconnect ALL the wires going to the circuit and use an ohm meter or continuity tester to test the wires.
    Remove the light bulb first, then there should be NO continuity from any wire to any other wire.
    Hot to neutral.
    Hot to ground.
    Neutral to ground.
    When you see from the breaker panel that there is a short between two wires, you can then disconnect the wires further down the line and test from there.
    Sometimes a metal clamp may cut into a wire causing a short. Or there my be a bare wire pointing out and touching a grounded electrical box. Or there may be a staple *through* the wire shorting it. Or when pulling wires with a lot of force through a hole in metal, this can strip the wire and cause a short to ground. Etc.
    How to use a continuity tester...
    http://www.dinosaurelectronics.com/Test_Fuse.htm
  5. rockycmt
    rockycmt Member
    Nov 13, 2007
    New York Metro Area
    All very good points Billy Bob. I will test the line between the switch and the fixture. I must have a staple stuck in it or a rip. I will confirm. In a major job does every wire get tested during 'roughIn' to catch things like this? I can see this heppening after walls are put up.
  6. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    A bounty hunter like in "Raising Arizona"
    MD
    Put a light bulb or a radio that's turned on across the CB while the CB is off.
    When the bulb goes out or the radio stops playing you've cleared the short.
    If the bulb never goes on or the radio doesn't play it is a bad CB.
  7. Rich B
    Rich B DIY Senior Member
    Sep 13, 2008
    New Jersey
    Are the boxes metal? You can sometimes use your nose to tell you where a dead short is after the breaker trips. Romex inside a metal box could have a nicked spot on a wire touching the box. OR BX without the proper "redhat" anti short bushing can have a bare spot at the wire where it exits the metal jacket. I worked with a guy who would say..."smell the plugs" to look for a shorted circuit....
Similar Threads: Circuit short
Electrical Forum discussion & Blog Chasing short on newly installed light circuit (also newly drywalled) Jul 11, 2011
Electrical Forum discussion & Blog Short Circuit but Breaker does not trip Jan 28, 2010
Electrical Forum discussion & Blog Wiring Split 15 & 20 amp circuits on same receptacle Wednesday at 7:05 PM
Electrical Forum discussion & Blog One switch, two circuits. Possible? Dec 14, 2016
Electrical Forum discussion & Blog 240v and 2 circuits Oct 29, 2016
