Circuit Breaker Question
Discussion in 'Electrical Forum discussion & Blog' started by eric3872, Jun 30, 2011.
  1. eric3872
    eric3872 New Member
    May 7, 2011
    new york
    I need to add a 30 amp breaker to my panel for a clothes dryer. I understand that I need a 2P 120/240 breaker. The problem is that I only have a 1" slot available.
    My panel is a cutler Hammer. I found this single pole 30/30 tandem breaker (which will work on my panel), but I dont understand the difference between a 30/30 tandem single pole and a 30Amp double pole breaker.
    http://www.acehardwareoutlet.com/ProductDetails.aspx?SKU=31184&
    I'm trying to avoid having to rearrange circuits or adding a sub panel. Will this tandem breaker work? Any help would be appreciated.
  2. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    No Eric that breaker will not work. That breaker works 2 120V circuits.
    It needs to be a double pole for the 240V that the dryer needs.
    It will take up two inches in your breaker panel.
    Have a good day.
    DonL
  4. SacCity
    SacCity In the Trades
    Mar 14, 2011
    Sacramento, CA
    You can use that breaker on two of your existing 120 volt lines to create the space needed for the 220 volt circuit.
    Michael
  5. eric3872
    eric3872 New Member
    May 7, 2011
    new york
    Thanks. So, Is there such a thing as a 2P 30amp breaker that's only 1"?
  6. eric3872
    eric3872 New Member
    May 7, 2011
    new york
    Not sure I understand what you're suggesting. This breaker is 1". It will only take one slot. Are you saying I could replace one of my single pole 15amp breaker with this one and combine the circuits from two of them into it to create the extra space?
  7. jadnashua
    They make skinny breakers to save some space in the panel, but physically, a 240vac breaker needs to be big enough to span two slots to be able to pick up both legs of the power to get the 240.
  8. hj
    1" 2 pole breakers are both on the same leg of the service panel. You need a breaker which connects to both legs, using two adjacent slots. Depending on your make and model, there are "piggyback" breakers which have a 30 amp 2 pole breaker in the center and (2) 15 or 20 amp ones on the outsides.
  9. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    I think it is a Westinghouse/Bryant/Cutler-Hammer-BD, Sylvania/Challenger/T&B.
    It would be nice hj, If it would work in that panel and only takes up two slots.
    What Michael said would work also, at the cost of two normal breakers.
    Have a nice 4th of July holiday weekend.
    And Remember Drink, Don't Drive...
    DonL
  10. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    For this style panel that is NOT a 2-pole breaker. It is a tandem/skinny/twin/etc breaker, which is two SP breakers.
    These are called "quad" breakers.
  11. Speedy Petey
    Jun 16, 2007
    NY State, USA
    Not for your panel. The only thing that would work would be a quad as stated above.
    [​IMG]
  12. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
  13. BobL43
    BobL43 DIY Senior Member
    Mar 25, 2011
    Retired Industrial Automation controls/tech s
    Long Island, NY
    Which ever way it is done, the 2 poles that supply the dryer 230volts should be a breaker assembly that has the trip levers tied together so they both flip off together. The 2 pole breaker in your first link looks like that. Having 2 seperate breakers, one plugged onto each phase without being next to each other and married together creates a safety hazard. If you turn off only one of these, the other will still be on supplying 115 volts at up to 30 amps to Neutral, if that is the breaker size. Your original post Don, I believe is the correct one. The service panels I have seen all require 2 inches of space to accomodate a 2 pole breaker and 1 inch tandem/twin breakers have 2 seperate protected feeds, but they are both on the same phase, 115 volts to neutral, 0 volts between the 2 individual protected circuits at the panel. Or if I misunderstood your post and your last sentence meant to rearrange the breakers to accomplish what I said, then good too.
  14. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Yes BobL.
    The 115 volt dual 1" breaker will have to replace 2 of the current 1" 20 amp breakers to make room for the 2" 30 amp 230 volt breaker. He currently only has 1 1" slot available.
    And yes the 30 amp 230 volt breaker has the trip levers tied together so they both flip off together.
    Are we on the same page ?
    Enjoy your day.
    DonL
  15. hj
    As an aside, the metal "bridge" in the breaker photo, is only needed if the outer breakers are also being used for a 220/240 device. It is removed to use it for two 120v circuits.
  16. BobL43
    Mar 25, 2011
    Long Island, NY
    Yes Don, same page :)
    Enjoy your day too; just came in from helping my wife re-arranging some pond plants. Guess who got in the pond and lifted out the potted pickel rushes?
  17. BobL43
    Mar 25, 2011
    Long Island, NY
    Iteresting looking breaker and metal clip on the 2 outside breakers.
  18. hj
    That is just to make it a double two pole breaker. Not necessary if you are going one 2 pole and two single pole circuits.
  19. BobL43
    Mar 25, 2011
    Long Island, NY
    So I can see from how it is set up. I like it.
Similar Threads: Circuit Breaker
Electrical Forum discussion & Blog 43v in circuit when breaker switched off Feb 16, 2016
Electrical Forum discussion & Blog AFCI breaker (in Wisconsin) needed for dedicated light circuit? Jul 30, 2014
Electrical Forum discussion & Blog Two pole arc fault breakers for multi wire circuits Jan 6, 2014
Electrical Forum discussion & Blog Sparks while changing outlet with circuit breaker off Dec 26, 2013
Electrical Forum discussion & Blog Circuit Breaker trips same time every day Aug 25, 2013
