circuit breaker question
Discussion in 'Electrical Forum discussion & Blog' started by fjbvax, Jan 27, 2009.
  1. fjbvax
    fjbvax New Member
    Nov 2, 2007
    Hi. I have a Cutler Hammer 200Amp electric panel box and want to add a 20 amp breaker dedicated to a new side by side refrig.. I find that their breakers are identified with 'CH' or 'BR'. The panel is 7 years old. Inside the door is a label with numerous 'CH's and one 'BR' listed. I'm not sure which one to buy.Can you help me? Thank You
  2. TedL
    TedL New Member
    Sep 17, 2006
    NY Capital District
    Look in the panel for the breaker that supplies your laundry. It s/b a 20 amp.
    Look at your open slots. Can they take the same?
    You'll find a selection of breakers for CH panels at the big blue box. Unless space is an issue, a single pole full size (width) breaker will work.
  4. jar546
    jar546 In the Trades
    Feb 20, 2008
    USA
    What color are the breaker handles and what color is the box?
    Tan? good chance it is a CH which is the higher end model. BR is the cheaper yet adequate model.
    Black breaker handles with a gray box then probably a BR.
  5. TedL
    TedL New Member
    Sep 17, 2006
    NY Capital District
    In any case, the simple answer is that a sample of what you need is almost certainly sitting in the box in front of you.
  6. fjbvax
    fjbvax New Member
    Nov 2, 2007
    TedL,
    Thank's very much. I'll do what you said. Floridian
  7. fjbvax
    fjbvax New Member
    Nov 2, 2007
    jar546 Thank's very much. I'll check the box,color's etc.. Floridian
  8. Alectrician
    Alectrician DIY Senior Member
    Jun 15, 2007
    Breakers....
    Tan = CH
    Black = BR
  9. fjbvax
    fjbvax New Member
    Nov 2, 2007
    220/221 Thank's very much. Good tip.
Similar Threads: circuit breaker
Electrical Forum discussion & Blog 43v in circuit when breaker switched off Feb 16, 2016
Electrical Forum discussion & Blog AFCI breaker (in Wisconsin) needed for dedicated light circuit? Jul 30, 2014
Electrical Forum discussion & Blog Two pole arc fault breakers for multi wire circuits Jan 6, 2014
Electrical Forum discussion & Blog Sparks while changing outlet with circuit breaker off Dec 26, 2013
Electrical Forum discussion & Blog Circuit Breaker trips same time every day Aug 25, 2013
