circ pump location
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by fsteyer, Jan 2, 2006.
  1. fsteyer
    fsteyer Member
    Apr 2, 2005
    Contractor
    Vermont
    Hallo -
    I'm doing a job where the circ pumps on a hydronic system are located on the return manifold "pulling" water through the loop rather than "pushing" on the heating supply manifold. I just have never seen it done that way and am curious if that an accepted practice.
    Thanks
  2. hj
    pumps
    I am not sure how common it is now, but in the 50's and 60's it was almost always done that way.
  4. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    In a closed pressurized system the concept of "pushing" of "pulling" the water doesn't apply.
    The return water is cooler and you are less likely to get cavitation in the pump if you are pumping the return water. That is significant with smaller high speed pumps that are used now. Also, the air vent is usually on the discharge end of the boiler which minimizes the air that will get to the circulator pump.
  5. fsteyer
    fsteyer Member
    Apr 2, 2005
    Contractor
    Vermont
    thanks ... I can see your points..... why are most systems set up with the pump on the supply side?
    thanks again
Similar Threads: circ pump
Plumbing Forum, Professional & DIY Advice Home run w/PEX how about a heat circulating pump? Feb 5, 2017
Plumbing Forum, Professional & DIY Advice Grundfos Timer Driven Hot Water Recirculation Pump - Name the Parts? Jan 25, 2017
Plumbing Forum, Professional & DIY Advice Using a recirculation pump to prevent freeze up of a supply line. Dec 12, 2016
Plumbing Forum, Professional & DIY Advice Hot Water Backfeeding - Issue with Recirculating Pump and Mixing Valve Jul 7, 2016
Plumbing Forum, Professional & DIY Advice Hot water comes quickly but recirculating pump is off? Jun 15, 2016
