chrome nipples leaking
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Taft, Jan 31, 2013.
  1. Taft
    Taft New Member
    Jan 31, 2013
    Illinois
    hello everyone. i have a clawfoot tub water supply leaking.just wondering the best way to fix.the leak is between the half inch female fitting on the shut off valve and the half inch chrome nipple going into it.i used teflon tape 2 to 3 wraps and a good snug hand tight with a partial tightening with a wrench.any body got any better advice on getting this to quit leaking?
  2. Terry
    Aug 17, 2004
    It may still be too loose.
  4. Taft
    Taft New Member
    Jan 31, 2013
    Illinois
    that was one thing i was considering.while turning the shut off valve and holding the pipe nipple my fear is bending or collapsing the chrome nipple.is that possible and if so any good ideas how to put a hold on both parts and not cause that to happen?thanks for any input.
  5. jadnashua
    Many of these parts sold here are made in China. The quality isn't always the greatest, torn threads from dull dies, inadequate depth, etc. Even if it is perfect, it takes a bit more than hand tight and a little more to create a good seal. The harder thing to get it tight enough is to do it without scratching the chrome off with the wrench or pliers. If there's another fitting on the other end of the nipple that has flats on it, use two wrenches, one on the valve, and a second one on the other fitting, and use that to tighten them both up nice and tight. Even if the other fitting doesn't have flats for a wrench, you might add one temporarily, and use that to tighten it up. THen, you must be careful not to loosen it when you take that fitting off. A good strap wrench might get it tight enough without scratching, and is a good tool to have around for things like showerheads, and other plumbing jobs with a nice finish you don't want to score up.
    Also, if you get it tight, then loosen it a bit, that can cause a leak with tape. You might want to switch to pipe dope. Once you get it nice and tight and leak-free, you can wipe the excess off, and not have to look at the tape, too.
  6. Taft
    Taft New Member
    Jan 31, 2013
    Illinois
    thanks for the advice i will have to try that in the morning.
Similar Threads: chrome nipples
Plumbing Forum, Professional & DIY Advice Chrome nipples to copper water feed lines??? Mar 27, 2012
Plumbing Forum, Professional & DIY Advice where can I get 5in chrome nipples? Sep 11, 2005
Plumbing Forum, Professional & DIY Advice Bending 3/8" chromed copper supply pipe to toilet Monday at 8:27 AM
Plumbing Forum, Professional & DIY Advice Please Help Me Find a single Chrome-KNOB that fits a Kohler 30467 diverter stem Jan 21, 2017
Plumbing Forum, Professional & DIY Advice Chrome p-trap question Aug 22, 2016
