chrome gooseneck to cpvc shower fitting - how do I ensure it doesn't leak behind the
Discussion in 'Shower & Bathtub Forum & Blog' started by Honest Bill, Nov 1, 2007.
  1. Honest Bill
    Honest Bill New Member
    Nov 1, 2007
    Arkansas
    I had a basement bath remodeled and the guy used all cpvc for the water lines (he's from California and is a real believer), including the fitting that the gooseneck screws in to. As this fitting is inside the wall, how do I connect the gooseneck where a plumbing leak won't be a potential problem, since the connection will be inside the wall? By the way, I'm a complete novice when it comes to plumbing. Thanks in advance, Bill
  2. jadnashua
    If the threaded fitting in the wall was cpvc, I'd be worried. I'd want a brass drop-eared fitting that could be screwed to a support to screw in the shower arm. Having it of plastic would risk splitting it if the arm (big lever!) got moved or knocked (or even tightened too much).
  4. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    In my own experience, the correct fitting in CPVC has a rubber washer inside as a seat for the gooseneck, and I installed mine with teflon tape also. And, you do not have to tighten the gooseneck enough to break the CPVC fitting in order to get a good seal!
Similar Threads: chrome gooseneck
Shower & Bathtub Forum & Blog Need chrome-plated pipe Mar 5, 2016
Shower & Bathtub Forum & Blog Easiest to Keep Clean Faucet Finnish: Chrome or Brushed Nickel/Stainless Steel Oct 16, 2013
Shower & Bathtub Forum & Blog mixing chrome finish from different brands Jun 29, 2013
Shower & Bathtub Forum & Blog Help! Need to update 1992 gold Delta 600 shower trim to polished nickel or chrome!! Apr 18, 2011
Shower & Bathtub Forum & Blog Help - need to shorten chrome shower riser pipe Aug 8, 2009
