Choices for a Shower Remodeling Plate
Discussion in 'Shower & Bathtub Forum & Blog' started by jadnashua, May 21, 2010.
  1. jadnashua
    Need to update a tub/shower control valve. Mother doesn't want me to go in from closet to get to the back. Looking for a remodeling plate. Found a nice looking one from Westbrass, but they're out of stock at the factory. Moen makes one, but is a bear to find on their site. The trim on the new valve (a Delta) is 7" in diameter, so that section needs to accommodate that trim (polished chrome).
    What are my choices? Need to get this in upstate NY before Wednesday, or things start to get messy. Will check the local plumbing supply houses Saturday morning, but hoping for something in stock, and not sure what the choices are.
    What have you guys used, and where did you get them?
  2. Terry
    Aug 17, 2004
    Local supply houses have always had the remodel plates.
    I haven't used the Delta plate, but the Moen plate plenty of times.
    It's too bad you can't go through the closet. You can pick up a white plastic wall plate just for that purpose that has a plastic frame and snap in door.
  4. jadnashua
    Well, I located another one that would fit by Delta RP29827, which is less than half the retail price of the Moen (which style-wise isn't as good a match), so I hope to find one in the morning, or at the latest Monday. HD carries it, but only on-line, and Lowes doesn't carry it or the Moen, that I could find. Anyone with other ideas, feel free. The closet is really an insert that would have to be totally removed, reinstalled, and maybe the trim replaced and repainted, so a bigger hole in the tub is probably the quicker and easier way. If it was just cut a hole in the drywall (or plaster in this case) in the closet, that would be the easier way to do things. The distance from the insert to the valve would just be too much if I cut a hole in it, plus, it gets its strength from the trim holding it to the doorframe and sitting on the floor.
  5. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Your customer is being unreasonable...
    Tell her I said so...
Similar Threads: Choices Shower
Shower & Bathtub Forum & Blog Bathtub/shower enclosure product choices Jan 26, 2017
Shower & Bathtub Forum & Blog Shower Pan and Enclosure Choices? Please Help Me Choose Oct 21, 2014
Shower & Bathtub Forum & Blog Tub and Shower remodel - fixture valve choices May 7, 2013
Shower & Bathtub Forum & Blog Choices in Delta shower faucets? Jul 30, 2009
Shower & Bathtub Forum & Blog Shower and lavatory choices ok? Apr 14, 2007
