Chlorine water treatment system
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Alexdc99, Feb 25, 2006.
  1. Alexdc99
    Alexdc99 New Member
    Sep 17, 2004
    Ontario, Canada
    Does anyone know what's in a turbidity filter and how often it needs replacing.
  2. Gary Slusser
    Retired
    There are many types of media that can be used. In some instances you can rule out some based on what the filter is supposed to be removing from the water.
    You replace whatever it is when needed, and that's when the filter can't do its job anymore. Of course you or a dealer should troubleshoot the filter to make sure the mineral is responsible for the problem.
  4. Alexdc99
    Alexdc99 New Member
    Sep 17, 2004
    Ontario, Canada
    One other question, if during the chlorine treatment I have normal (7.2 or 3 ph) but after the chlorine is removed I now have low ph, say maybe low 6's. What could cause it to go so low during the different processes. After everything my chlorine is 0, hardness is 0 and iron is 0.
    Thanks
  5. Gary Slusser
    Retired
    I suspect the raw water pH test result is invalid. Iron can interfer with a pH test.
    Otherwise I have no idea why the treated water pH would be so much lower. Chlorine raises pH.
Similar Threads: Chlorine water
Plumbing Forum, Professional & DIY Advice Can I fix mild odor in hot water with chlorine injector? Dec 12, 2014
Plumbing Forum, Professional & DIY Advice Chlorine removal POE vs POU Jan 28, 2013
Plumbing Forum, Professional & DIY Advice Plumbing problems after shocking well with chlorine! Help Apr 25, 2012
Plumbing Forum, Professional & DIY Advice Use Chlorine (Charcoal) filter in Whole House Sediment Filter Housing ?? Mar 3, 2011
Plumbing Forum, Professional & DIY Advice 1/2" Pex Waterline Guide. What Do You Think? Yesterday at 7:02 AM
