Chimney liner versus a "scuttle"
Discussion in 'HVAC Heating & Cooling' started by salesman217, Oct 24, 2007.
  1. salesman217
    salesman217 New Member
    Oct 24, 2007
    New guy here. Thanks in advance.
    I contracted with Sears (bad idea?) to install a natural gas furnace in a 1900s to 1920s house in Cleveland, OH. Every independent source I talked with prior to doing this deal said that I needed a chimney liner since the furnace I was replacing was around 40% efficiency and the new one would be around 80%.
    Contractor shows up and says the chimney is too tall (protruding 10 or 15 feet above the roof of a three story house) and might fall over, so he's going to install a "scuttle" (technical install instructions call it a 'chimney adapter kit').
    Supposedly the chimney liner is supposed to prevent condensation, yada yada, acid build up, yada yada, carbon monoxide seepage yada yada.
    As best I understand, the "scuttle" dries the gases before they go into the chimney so condensation isn't an issue. I don't understand how the scuttle would prevent CO seepage however.
    Anyway, the contractor tried to sell me the idea of the "scuttle" as a no cost upgrade over a chimney liner saying that the "scuttle" is about $300 but the liner (aluminum ducting) is $100 tops.
    Any advice would be greatly appreciated.
    Thanks,
    Salesman
Similar Threads: Chimney liner
HVAC Heating & Cooling Help on Chimney Repair Oct 18, 2015
HVAC Heating & Cooling Oil Funance Chimney issue Mar 4, 2011
HVAC Heating & Cooling Chemical odor from central heating's chimney Dec 21, 2008
HVAC Heating & Cooling closing off b vent chimney Oct 5, 2008
HVAC Heating & Cooling Questions; gas/oil, chimney, hot water.. ?? Jun 29, 2008
