check valve placement
Discussion in 'Boiler Forum' started by msgale, Jun 11, 2009.
  1. msgale
    msgale Member
    Sep 28, 2006
    can a one inch swing check valve be placed in a vertical pipe and still worK? Or do they have to be horizontal?
    It's for near-boiler piping, to prevent domestic hot water heater usage improperly getting hot water to the house hydronic system in summer
  2. jadnashua
    A little more info would be required. There should not be any cross-coupling between hydronic and potable water. Do you have say a demand type system in your boiler you shut off for the summer and use a tank instead? I'd consider just using a valve(s) to shut one off and open the other.
    Check valves can (normally) go horizontal (properly oriented) or vertical. If this is for potable water, you'll need probably a bronze, SS, or plastic approved for potable water use. Being hot may create some other problems.
  4. msgale
    msgale Member
    Sep 28, 2006
    this is for the water heated by the mod-con boiler in a hydronic system. Now, its a primary/secondary set of loops, one zone only.
    The revision is to add an indirect water heater. For summer use of the water heater, i need check valve to protect against boiler-heated water going thru the house radiators.
    none of this is potable water. the heated hot wster for human use is on a separate set of pipes
  5. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    Indirect water heater. Check valve goes after DHW pump before the tee where the return from the sysytem goes into the boiler. On the verticle is fine with a swing check.
    Might want to wait for Thatguy, nhmaster or HJ to weigh in with their opinions.
  6. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    What you need is a flow check valve which is not like a regular swing or ball check in that it has a weighted gate. Check out www.taco-hvac.com What you probably want is a Taco 219.
  7. msgale
    msgale Member
    Sep 28, 2006
    i can't find 219 in taco, is ther another name?
    tried the web site, no luck
  8. msgale
    msgale Member
    Sep 28, 2006
    OK, found the 219...
    How is that different or better than a plain swing check valve?
  9. nhmaster
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    The check in a standard swing check is not heavy enough to always stay closed against thermal migration. A flow check has a heavier check assembly.
  10. msgale
    msgale Member
    Sep 28, 2006
    ok, sounds reasonable, thank you , all of you, for the info.
    I love this board
Similar Threads: check valve
Boiler Forum Any maintenance I can do to my boiler? Also a question if I'm missing a check valve... Nov 16, 2014
Boiler Forum Boiler Air Purge Check Jan 10, 2016
Boiler Forum Replacing old NG boiler / water heater - check my sizing please? Sep 6, 2014
Boiler Forum Can someone check my Math and help with calculation? Dec 6, 2013
Boiler Forum Check please!!! Sep 10, 2013
