Check valve on a closed loop hydronic system?
Discussion in 'HVAC Heating & Cooling' started by CHRISUPNORTH, Nov 23, 2008.
  1. CHRISUPNORTH
    CHRISUPNORTH New Member
    Nov 23, 2008
    As mentioned in another thread I am putting together a small closed loop hydronic system . The Taco circ pump I have purchased has a integral check. My system will have about 18" of head.
    Should I remove the check in the pump?
    What are the advantages/disadvantages of removing it?
    Regards,
    Chris
  2. jadnashua
    Leave the check valve...
  4. CHRISUPNORTH
    Nov 23, 2008
    Thanks for the reply Jim.
    I am trying to learn here so help me out. Can you expand on why you think it better left in?
    Chris
  5. jadnashua
    Without a checkvalve, when the pump is off, you'll still get circulation because of the difference in height and temperature. So, things could continue to get heat when you don't want it.
Similar Threads: Check valve
HVAC Heating & Cooling Check valve for open-direct radiant heating system May 14, 2013
HVAC Heating & Cooling Taco Check Valve Chatter Dec 14, 2012
HVAC Heating & Cooling Mini Splits, Single vs Multi Zone Condensers Sanity Check Jul 21, 2016
HVAC Heating & Cooling How to Check a Boiler for Freezing Cracks? Sep 10, 2009
HVAC Heating & Cooling Issue with Taco 241 swet-check Jan 19, 2009
