ton
- Messages
- 44
- Reaction score
- 0
- Points
- 6
I have a sandpoint well. In take pipe is plastic 1 1/4" pipe 25 ft into the cottage. I want to heat trace it with a in pipe trace. I cannot for my check valve is located 2 ft up on the galanized portion of my sand point. (at the well) Heat trace cannot go through swing valves.
Is it advisable to move the check valve and install it on the pump and than start my heat trace after the check valve and down my sand point below the frost line.
I also wanted to install quick connects at the pump and at the well for quicker shut downs in the fall. Anyone had luck with these.
I also found a check valve that can be accessed through the side (bolt). This would enable me to disengage it drain water out of it. Thank you for your help your board has been very helpful
