Check DWV Design
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by rmelo99, Jan 7, 2008.
  1. rmelo99
    rmelo99 Network Engineer
    Jul 7, 2006
    Network Engineer
    Can you guys check out this drain layout. This is a top view. All pipes are running left to right in between a joist. I have shown vent takeoffs for shower and toilet. The vents will actually rise up into the wall that runs parallel to this whole setup and then over to the right to tap into the 3" stack out to the roof.
    BTW the 2 wyes in the picture are sanitees(the program didn't have those so I used wyes in my diagram).
  2. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    Reverse the direction of the tee for the shower drain
    The washing machine drain needs a vent on it before it catches the shower drain
    Why can't you turn up tees instead of laying the fittings on 45's? They are permissable in this fashion but I'd thought I'd ask.
    I'm getting jealous of all these sophisticated drawings; feeling like MC Hammer............Can't touch this
  4. rmelo99
    Jul 7, 2006
    Network Engineer
    Thanks for the quick reply. I've been hunting for a program to do my drawings (IT GUY HERE)
    The drawing isn't complete. The washer will actually connect further down the line on the left via a long 90 elbow that drops into the 2" line on the left. It will have it's own vent that will tie back in with the shower,and toilet vents on the way back to the 3" stack on the right about 5' up horitzontally 2" line.
    I have to use roll the 45 deg because of joist height and to maintain line slope.
    Any other problems?
  5. Dunbar Plumbing
    Apr 18, 2005
    Not that I can see from what you've posted, looks fine.
    Others will chime in so wait to see if they pick up on anything.
    I'm assuming you'll take all those vents off the individual fixtures and tie back into the main vent stack?
  6. rmelo99
    Jul 7, 2006
    Network Engineer
    Each fixture will have it's own vent
    Shower 1.5"
    Washer 1.5"
    Toilet 2"
    Sink 1.5"
    These will all tie back to a 2" horizontal run that will run almost parallel to the drain line but inside the wall at a height of about 5'. That will tie into the 3" stack with a 3x3x2 tee.
  7. frenchie
    frenchie Jack of all trades
    Dec 30, 2006
    Caretaker
  8. rmelo99
    Jul 7, 2006
    Network Engineer
    OMG...that program looks great..off to google. THANKS!
    OK got the program...i can get individual models from the 3d warehouse...but how do i get the entire collection so I have all the fittings in the program?
Similar Threads: Check Design
Plumbing Forum, Professional & DIY Advice New second floor bathroom: Drain design check Oct 4, 2009
Plumbing Forum, Professional & DIY Advice New shower / check valve question Feb 9, 2017
Plumbing Forum, Professional & DIY Advice Island/Peninsula Loop Vent - Final Check Jan 5, 2017
Plumbing Forum, Professional & DIY Advice Sanity check on pipe sizes for new construction Nov 26, 2016
Plumbing Forum, Professional & DIY Advice 2 hot lines to one fixture with check valve Oct 22, 2016
