Changing out direct vent waterheater
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by xdigggerx, Nov 5, 2008.
  1. xdigggerx
    xdigggerx New Member
    Nov 3, 2008
    I need to know if I can replace a direct vent waterheater in a mobile home with a regular mobile home water heater if I put a vent in the wall to my washroom so it can get air.
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    I would call a plumber for the replacement of the water heater.
    You do like waking up in the morning and having the trailer intact don't you?
  4. jimbo
    jimbo Plumber
    This is a gray area as far as what codes may apply. But the important thing would be to provide proper combustion air. If the WH is located in an enclosed space, it needs a vent inlet within 14 inches of the floor AND and inlet within 14 inches of the ceiling. Each of these needs to be about 1 sq. in. per 1000 BTU of the water heater if taking fresh outside air, and about 4 sq. in. per 1000 BTU if taking air from inside the home. Naturally, you need to run a flue pipe straight up through the roof, observing proper clearances to combustibles in all directions.
    If you do not already have a carbon monoxide detector in the home , we strongly recommend this for all homes with fuel burning appliances.
Similar Threads: Changing direct
Plumbing Forum, Professional & DIY Advice Changing direction of new PVC pipe while replacing slab on grade in new house Nov 13, 2012
Plumbing Forum, Professional & DIY Advice Changing main shutoff Oct 17, 2016
Plumbing Forum, Professional & DIY Advice Garage washing machine : changing from 1" drain to 2" drain pipe May 28, 2016
Plumbing Forum, Professional & DIY Advice Need advise on changing main Sewer Trap. Sep 2, 2015
Plumbing Forum, Professional & DIY Advice Changing toilet -- ran into problem. Floor mount, Rear outlet Apr 5, 2015
