changing out all the cheap plastic stop valves with 1/4 turn stops.
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by jm66208, Jul 29, 2013.
  1. jm66208
    jm66208 Member
    Aug 17, 2011
    Kansas City
    Problem is, they're all compression fitting and not enough pipe left to cut the old compression ring off and get the new ones on. Can I just use the old compression ring & nut with the new valve? Thanks!
  2. hj
    MAYBE, it depends on which thread pitch they have. But a "sleeve puller" will remove them without cutting any tubing off.
    [​IMG]
  4. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    If the original stops are cheap plastic, what then is the quality of the original ring and nut? Most sleeve pullers use the original nut to engage the compression ring but doing so could put squeeze pressure against the pipe. A ring splitter may be needed in the most difficult cases.
    http://www.saf-t-kut.com/products/compression-ring-remover/
    When I changed out the last two stops, I couldn't get the rings to budge and didn't have that tool. I ended up using my Dremel tool to split the ring. In doing so, I nicked the pipe and had to shorten it 1/4" so that the new ring had a smooth surface to seal against.
  5. jm66208
    jm66208 Member
    Aug 17, 2011
    Kansas City
    Ahh, forgot about those ring removal tools. Question..I haven't removed any of the old ones yet, but sometimes I see that the old one was tightened so much that there is obvious distortion in the tube. Will the ring still pull off, and is the tube still usable? Problem is, someone took the time to cut the tube short enought that the stops butt right up to the escutcheon. Looks nice, but they used cheap plastic gate valves?!?!
  6. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    Ja, I've seen cases where the pipe got distorted and doubt a puller would work then. If the nut is tight to the escutcheon, then the ring splitter wouldn't work either unless you cut the nut off with a Dremel tool.
    Another thing I've encountered is the amount of pipe stub protruding after the ring can vary. On the last pair of stops I changed out, the old ones had a deeper recess for a longer pipe stub so if I were to reuse the nut/ring, I would have had to shorten the stub. There was no way a tubing cutter would fit so was faced with having to use the Dremel tool. In the end it was easier to split the ring.
    On some cabinets, the back is made of thin material and spaced away from the wall so you may have some flex room to push back the escutcheons. In fact, that was what I had to do to gain the room to cut off the ring.
    It will only take you a minute or two to find out whether reusing the nut and ring is an option.
  7. Terry
    Aug 17, 2004
    Then it's doubfull that the copper was compressed if the stops are plastic. Often, you can just snap the metal ring with pliers.
    And no, you can't reuse the back nut if it's plastic.
  8. jm66208
    jm66208 Member
    Aug 17, 2011
    Kansas City
    Should have clarified. Valves are chrome. Handles are clear plastic and valve stems are plastic (probably nylon to be more precise).
    Edit: OK, not rocket science here. Headed to supplier to pick up a Saf-t-kut cutter & a Pasco puller. Should cover me...
Similar Threads: changing cheap
Plumbing Forum, Professional & DIY Advice Changing main shutoff Oct 17, 2016
Plumbing Forum, Professional & DIY Advice Garage washing machine : changing from 1" drain to 2" drain pipe May 28, 2016
Plumbing Forum, Professional & DIY Advice Need advise on changing main Sewer Trap. Sep 2, 2015
Plumbing Forum, Professional & DIY Advice Changing toilet -- ran into problem. Floor mount, Rear outlet Apr 5, 2015
Plumbing Forum, Professional & DIY Advice Changing fron 4-inch faucet to eight Sep 3, 2014
