Changing oil furnace to 2 line
Discussion in 'HVAC Heating & Cooling' started by thunderhead, Apr 5, 2009.
  1. thunderhead
    thunderhead New Member
    Mar 7, 2009
    Illinois
    I have a Beckett AFII oil burner. The tank is lower than the pump and I can only run a couple minutes before it gets air in the pump and have to bleed it out again. Manual says to use two pipe system if tank is lower. It also says to insert a plug in the pump. Where does this plug go? I am trying to attach a pic of the pump. I think the bottom two fitting are in and out, so after I find where to put the plug all I have to do is run a line from the outlet back to the fuel tank? TIA
Similar Threads: Changing furnace
HVAC Heating & Cooling changing heat only tstat to heat and cool tstat May 3, 2010
HVAC Heating & Cooling Changing boiler water pump. Mar 14, 2010
HVAC Heating & Cooling Rheem furnace model r92pa not lighting all the time Jan 24, 2017
HVAC Heating & Cooling Chattering Furnace Contactor Jan 7, 2017
HVAC Heating & Cooling Dripping Sound from Attic Furnace/AC? Jan 1, 2017
