Changing fixture locations
Discussion in 'Toilet Forum discussions' started by robertrt, Aug 20, 2005.
  1. robertrt
    robertrt New Member
    Aug 20, 2005
    Moving toilet to stall shower location and vice versa. Are there any problems with the waste pipe differences and how to overcome them. :confused:
  2. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    Local plumbing codes dictate the correct config to placement of fixtures. You will need to know this in order to make the changes without problems with piping in the future.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I'm afraid you have more problems than you realize. The shower drain should be 2", and the toilet requires at least 3". Yours may be 3" or 4". The location of the two drains as related to the walls are not the same. In short, your entire plumbing will have to be redone. As often mentioned by pros on this BBS, nothing is impossible...given enough time and enough money. This job will require plenty of both.
  5. robertrt
    robertrt New Member
    Aug 20, 2005
    Thank you gentlemen. I thought that there would be an issue with the diameter of the waste pipes. I am going to rethink this move and avoid a total repiping. :(
Similar Threads: Changing fixture
Toilet Forum discussions Seeking advice on changing the fill valve of a Toto Pacifica CST804S Dec 29, 2015
Toilet Forum discussions changing toto fill valve cap May 27, 2013
Toilet Forum discussions Purchased Toto Guinevere toilet. Changing out handle? Jan 18, 2010
Toilet Forum discussions Is Flush Standard in US Changing? Oct 30, 2009
Toilet Forum discussions Changing out a 1955 Toilet Oct 1, 2008
