Changing boiler water pump.
Discussion in 'HVAC Heating & Cooling' started by kskier, Mar 14, 2010.
  1. kskier
    kskier Home Handyman
    Sep 4, 2007
    Home Handyman
    Buffalo NY
    My water pump on my boiler is making noise. I was going to change it out. It is an American Standard with a Gossit pump. On the zone manifold there are drain valves. Before changing pump, I was going to shut off water supply to the boiler, then open up drain valves to relieve the pressure and then change out the pump. After installing the pump before I turn power back on to the pump, do I turn the water supply to the boiler and open the drain valves to let air out, or turn power on first, then open up the water and drain valves........thanks .......Karl
  2. jadnashua
    You want to get as much air out as you can before you turn the power back on. The pump's bearing are lubricated by water. It won't last that long running dry.
Similar Threads: Changing boiler
HVAC Heating & Cooling changing heat only tstat to heat and cool tstat May 3, 2010
HVAC Heating & Cooling Changing oil furnace to 2 line Apr 5, 2009
HVAC Heating & Cooling Adding a Zone to a Boiler Jan 9, 2017
HVAC Heating & Cooling Thermocouple for older boiler Nov 3, 2016
HVAC Heating & Cooling Advice new boilers for two apartment home. Jan 19, 2016
