Changing bath tub drain cover plate
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by bezoar, May 31, 2011.
  1. bezoar
    bezoar New Member
    Dec 15, 2008
    Seattle, WA
    Anyone have any suggestions on how to remove this contraption on the bathtub overflow?
    [​IMG]
    I changed the stopper to a popup and want to put on a plain face plate, but the current face plates have too narrow a width and don't lie flush with the tub surface. The local plumbing supply store suggested putting in a 2 hole to 1 hole bracket, but I don't know how to get this thing out to put in the bracket. Any advice is greatly appreciated.
  2. Terry
    Aug 17, 2004
    I believe that spins off.
  4. bezoar
    bezoar New Member
    Dec 15, 2008
    Seattle, WA
    Man you are fast Terry. What type of tool would you use to grip it?
  5. Terry
    Aug 17, 2004
    I would maybe be able to get it with my plumbers pliers, and if not those, I would tap on the lugs with something. You have to be careful not to miss though and chip the tub.
  6. hj
    LEAVE it alone. IF you remove it, you will have NOTHING to attach the faceplate to, since the bolt holes are in the "locknut", and that is what is keeping the overflow from leaking. The "local plumbing store" did NOT know what they were talking about. A 2 bolt to one adapter plate, will add even more depth to the device. Just get a deeper two bolt plate, they DO make them.
  7. bezoar
    bezoar New Member
    Dec 15, 2008
    Seattle, WA
    Ok, I'll try to find one. I haven't been able to find one that deep at the 2 local plumbing supply stores I've tried, and HD and Lowe's definitely don't have anything that will fit the bill.
  8. Terry
    Aug 17, 2004
    hj is right. I was thinking complete replacement, and that's not what you are doing.
  9. hj
    quote; HD and Lowe's definitely don't have anything that will fit the bill.
    They ONLY have items that will fit 99% of the customer's needs. You are in the 1%, go to a good plumbing supply store. If necessary, get one with the trip lever, but do not connect anything to the lever.
  10. aswiercz
    aswiercz New Member
    Aug 31, 2014
    Any luck on finding a face plate that fits? I've run into the same problem with my tub, which appears to be the same style/brand as yours.
  11. hj
    On possibility is to saw or grind the "stubs" so they are flush with the ring.
    fullysprinklered likes this.
  12. fullysprinklered
    fullysprinklered Active Member
    Jun 15, 2014
    self-employed plumber-electrician doing residentia
    Georgia
    I agree with HJ. If it's the threaded parts sticking out that's the problem, grind them off and if necessary, run a tap through them to restore the threads. I carry a 4" grinder with a diamond blade for special occasions such as this.
Similar Threads: Changing bath
Plumbing Forum, Professional & DIY Advice Changing bath lavortory Jul 1, 2007
Plumbing Forum, Professional & DIY Advice Changing main shutoff Oct 17, 2016
Plumbing Forum, Professional & DIY Advice Garage washing machine : changing from 1" drain to 2" drain pipe May 28, 2016
Plumbing Forum, Professional & DIY Advice Need advise on changing main Sewer Trap. Sep 2, 2015
Plumbing Forum, Professional & DIY Advice Changing toilet -- ran into problem. Floor mount, Rear outlet Apr 5, 2015
