changed pump
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Sopal, Sep 17, 2005.
  1. Sopal
    Sopal New Member
    Sep 17, 2005
    2 weeks ago,, I changed my pump,, worked great till recently ,, now after 3 -5 mins of useage,, I loose pressure ,, have to bleed air out of the pump ,, then things are fine till it happens again. which doesnt take long. Im thinking my bladder tank got damaged during or after the installation? I cant think how air would be getting in anyother way,,, any ideas?
  2. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    The air won't be from the bladder tank.
    Am I to assume this is a jet pump?
    bob...
  4. Sopal
    Sopal New Member
    Sep 17, 2005
    yea.. a shallow well jet pump ,,, was told today,, that it must be sucking air from the well side ,, Ive tighented all the connections I can get to ,, without digging up the well,, will HATE to have to get a new well dug
  5. speedbump
    Jul 15, 2005
    Riverview, Fl.
    If you are sure no air leaks exist in the area of the pump, I would think the next step would be replacing the suction line, or pulling the droppipe and inspecting/replacing. Which ever one is easier to do would be my first choice.bob...
  6. neili
    neili sales of irrigation, pumps, water wells
    Sep 17, 2005
    north dakota/montana
    Attempt to measure the water level in the well. Your local pump man should have a sounding meter to determine the level. If he does not, you could attempt to make your own. I have had customers that use an extension cord and an ohm meter. If you lower an extension cord into the water and have an ohm meter hooked to the other end, the ohm meter will show continuity when the water shorts out the end of the extension cord. Measure the water level when the pump is off and measure it well the pump is running. If the level drops below your suction line that would explain your problem. If the water level is dropping that low it might not be the end. You may be able to redevelop the well with air, surging, pumping, chemicals, or other methods.
    Also, remember that any time you put anything down a well you should disinfect the well with chlorine. The best thing to do is use a high concentrate chlorine tablet, but good old bleach works as well. Place a gallon or two down the well after you have done anything down hole.
    ding meter to determing the level. if he does not, you could attempt to make your own. i have
Similar Threads: changed pump
Pumps and Tanks Well Forum & Blog. Water is life. Lake water pump cracked housing - trying to determine best option with changed needs Apr 29, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Helplease....Sprinkler pump and pressure tank Saturday at 7:51 PM
Pumps and Tanks Well Forum & Blog. Water is life. Well pump varies, Please help I'm clueless Wednesday at 9:38 PM
Pumps and Tanks Well Forum & Blog. Water is life. Shallow well jet pump failing to reach cutoff Wednesday at 7:59 AM
Pumps and Tanks Well Forum & Blog. Water is life. Poly vs schedule 80 pump vibrating loose Tuesday at 12:36 PM
