change this kitchen drain pipe or not bother
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by nothingeverworks, Feb 1, 2010.
  1. nothingeverworks
    nothingeverworks Member
    Mar 26, 2007
    Florida
    I am changing out my kitchen sink and faucet. Trying to decide whether to change the drain pipe. Takes up a lot of space but am undecided whether it's worth the bother or not and also concerned about the lack of pipe. i would need to cut it right at the wall.
    [​IMG]
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    If I am seeing your picture right, you have a double sink draining with no p trap at all. If that is right, you need a plumber.
  4. Spaceman Spiff
    Spaceman Spiff Architect
    Architect
    Salt Lake City, Utah
    I think the P trap is missing because the sink is missing. I wouldn't bother with messing with it. Just put in 2 new tubing traps and go with it. If you put in a tubing tee with a baffle your sinks will probably drain a lot slower than the 2" drain that is there.
  5. nothingeverworks
    Mar 26, 2007
    Florida
    yes i removed the P taps with the sink
  6. asktom
    asktom Member
    Nov 9, 2009
    Victor, MT
    Two traps on one trap arm does not meet code. The easiest fix would be to use one trap and cap the other side.
  7. Gary Swart
    Sep 1, 2004
    Yakima WA
    I'm glad I was not seeing the picture correctly! I was thinking if anyone was so inept not know that P traps were needed, there wasn't much hope of giving on line help. As others pointed out, you do need to make some changes, but it is a fixable situation. Retrofitting kitchen and bathroom drains can be frustrating because of the space restraints, but at least PVC is easier to connect than cutting and threading galvanized pipe! Now I can go about my day somewhat relieved. ;)
  8. nothingeverworks
    Mar 26, 2007
    Florida
    i can do that! didn't know it wasn't code but that's the way the house came
  9. Spaceman Spiff
    Architect
    What's the code reference for this?
  10. nothingeverworks
    Mar 26, 2007
    Florida
    so i took the second P trap out and connected the pipe from the insinkerator directly to the drain pipe with a "T" connection joint and capped off the other side.
    Are you suppose to use Teflon tape on the threads of the PVC I am capping? (As is standard, I did NOT use teflon tape for the P-trap and other drain connections)
  11. nothingeverworks
    Mar 26, 2007
    Florida
    bump. anyone?
  12. hj
    There was nothing wrong with the original connection. But it was "overdone" if the installation did not need that particular configuration. Assuming you used the correct "tee" and piping, you probably did it properly. My picture did NOT show any missing traps.
  13. nothingeverworks
    Mar 26, 2007
    Florida
    Sorry, my question is whether I should be using Teflon tape on the PVC connection where I've capped it. I know you DON'T use it on the drain kit parts (P-traps, tailpiece, etc)
  14. hj
    You SHOULD, but as a practical matter, it would not normally leak unless the drain is plugged, and might not even then.
  15. nothingeverworks
    Mar 26, 2007
    Florida
    okay. thanks much
Similar Threads: change kitchen
Plumbing Forum, Professional & DIY Advice Change Kitchen to Softened on PEX Sep 15, 2016
Plumbing Forum, Professional & DIY Advice When to change water filter. Dec 29, 2016
Plumbing Forum, Professional & DIY Advice Ok to change this sanitary tee to a long sweep combo? Sep 10, 2016
Plumbing Forum, Professional & DIY Advice Change orientation of quarter turn lever on water main May 23, 2016
Plumbing Forum, Professional & DIY Advice Bathroom Horizontal Wet Vent W Direction Change? May 6, 2016
