Change flare fitting
Fred Woods
Missouri
I have a 3/4" copper supply coming into the house that has a flare fitting connecting the shutoff valve. The valve is defective. I'm wanting to know if I could just remove the flare fitting and sweat a different fitting to connect new valve to.
Kreemoweet
Seattle. WA
A flare fitting means the supply line is "soft" copper. That stuff is frequently less-than-round and difficult to
get a good solder joint to. There is really no reason to eliminate the flare joint as adapter fittings for pipe
thread, compression joint, solder joint, etc., are readily available.
A flare fitting means the supply line is "soft" copper. That stuff is frequently less-than-round and difficult to get a good solder joint to.
Well, there is that about it. Soft copper is rarely round like hard copper. If you can keep the flare, that's one less worry.
